Arduno Like Library: new idea for Bascom user
pinkfloyd11
PostPosted: Sat Dec 13, 2014 9:48 am    Post subject: Arduno Like Library: new idea for Bascom user Reply with quote
Hello
my idea is simple: write library in bascom with the same "style" used in Arduino.
If anyone of us write one or more "Arduino Like Library" we could have rich archive in few time.
It could be still better if we could have list of this library directly in IDE (Code Project - PDF viewer -...- Arduino Like Library )
Here my Idea
'      Arduino Like Library
' NAME: RGB LED
' VERSION: 1.0
' AUTHOR: Giuseppe Pezzella
' SPECIAL THANKS: bzijlstra
' HARDWARE PERIPHERALS: Timer 0, Timer 1, Timer 2
' PINOUT ATMEL: (PB.1-GREEN ANODE)    (PB.3-RED ANODE)   (PD.6-BLUE ANODE)
' PINOUT ARDUINO UNO:  (9-GREEN ANODE)   (6-RED ANODE)   (11-BLUE ANODE)
' LIBRARY METODE:
'       -----> START_RGB_LED: Start Timer that drive LED
'       -----> STOP_RGB_LED:   Stop Timer that drive LED
'       -----> RGB_LED_COLOR: Set color to RGB LED
Config SUBMODE = NEW
$regfile = "m328pdef.dat"
$hwstack = 32
$swstack = 32
$framesize = 32
$crystal = 16000000
$Include "RGB Library.inc"
Dim Random1 as byte
Dim Random2 as byte
Dim Random3 as byte
DO
   START_RGB_LED
         Random1 = rnd(255)
         Random2 = rnd(255)
         Random3 = rnd(255)
         RGB_LED_COLOR Random1, Random2, Random3
         Wait 1
   STOP_RGB_LED
LOOP
END
'Timer configured as PWM
Config Timer0 = Pwm , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Config Timer1 = Pwm , Pwm = 8 , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Config Timer2 = Pwm , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Red_pwm Alias Pwm0a
Green_pwm Alias Pwm1a
Blue_pwm Alias Pwm2a
Config Portb.3 = Output    'RED LED
Config Portb.1 = Output     'GREEN LED
Config Portd.6 = Output    'BLUE LED
Stop  TIMER0
Stop  TIMER1
Stop  TIMER2
'_______________________________________________________________________
SUB RGB_LED_COLOR (Red_Color as byte, Green_Color as byte, Blue_Color as byte)
   Red_pwm = Red_Color
   Green_pwm = Green_Color
   Blue_pwm = Blue_Color
END SUB
SUB START_RGB_LED
   Start  TIMER0
   Start  TIMER1
   Start  TIMER2
END SUB
SUB STOP_RGB_LED
   Stop  TIMER0
   Stop  TIMER1
   Stop  TIMER2
END SUB
Paulvk
PostPosted: Sat Dec 13, 2014 11:32 am    Post subject: Reply with quote
Hello pinkfloyd11
This is what I have been trying to do with my projects as much as possible.
By making the subs and functions separate .INC files so all you do is include them
with submode new they do not have to be declared
I wanted to add to the Wiki but I keep timing out so can not navigate through it
I have this problem with the forum but not as bad I think it is more to do with my ISP.
If people adopt the project mode and use Local variables as much as possible then the code in the .INC files would become portable.
Regards Paul
pinkfloyd11
PostPosted: Sat Dec 13, 2014 2:16 pm    Post subject: Reply with quote
Hi Paul
extract from your project piece of code that could be reused from us and post here...
I invite all to post here their piece of code
Giuseppe
PostPosted: Sat Dec 13, 2014 5:19 pm    Post subject: Reply with quote
Yes for Include and Sub Mode = New because only used Subs are compiled from included files Very Happy
But no for using three timers for human eye Laughing
Code is not mine
$crystal = 16000000
Config Timer0 = Timer , Prescale = 8
Enable Timer0 : On Timer0 Timer0_isr
Rd Alias Portb.0                                            'any pin
Gd Alias Portb.1                                            'any pin
Bd Alias Portb.2                                            'any pin
Dim Count As Byte
Dim Rled As Byte , Bled As Byte , Gled As Byte
Rled = 80                                                   'value in %
Gled = 0                                                    'value in %
Bled = 90                                                   'value in %
'*** START ***
'*** END ***
Timer0_isr:
 Incr Count
 If Count = 100 Then Count = 0
 If Count < Rled Then Set Rd Else Reset Rd
 If Count < Gled Then Set Gd Else Reset Gd
 If Count < Bled Then Set Bd Else Reset Bd
aphawk
PostPosted: Mon Dec 15, 2014 2:49 am    Post subject: Reply with quote
I think that we must create a standard for this, because in Arduino's code we need to declare the pins that will be used for the functions on libraries.
This definitions must be passed in the init code to the library.
I have made many codes for peripherals that can be converted to libraries, but someone ( maybe Mark ??? ) must create one stardard
to all people follows, and this can be very usefull to all kind of users.
But everyone must follows this when creating one library.
Paulo
Deanus
PostPosted: Mon Dec 15, 2014 9:00 am    Post subject: Reply with quote
Hi All,
Arn't you lot in the wrong section here since there is already a section for BASCOM-ARDUINO in the main menu.
BASCOM-ARDUINO
A forum to discuss using BASCOM-AVR with ARDUINO hardware. Notice that this is a USER forum. It is for users, by users. MCS Electronics provides this as a free service. This is NOT the support system which is at http://www.mcselec.com/support-center/
Moderator Duval JP
Dean
