REPLACECHARS and extended ASCII
mrak
PostPosted: Thu Oct 23, 2014 10:06 pm    Post subject: REPLACECHARS and extended ASCII Reply with quote
I'd like to use Replacechars function to exchange in a string some of the text characters (basic ASCII) into the extended characters. A natural way seemed to use the {xxx} notation.
In the example:
$regfile = "m168def.dat"
$crystal = 8000000
Dim Stemp As String * 20
Stemp = "Hello world"
Replacechars Stemp , "d" , "{255}"
Print Stemp
the "Hello worl{" string is generated as the output rather than expected string with the extended character at the very end of the string.
I'd like to ensure it is an accidental error in the Replacechars function or this should work intentionally in this way.
Thank you in advance for your answer!
makarak
PostPosted: Thu Oct 23, 2014 10:14 pm    Post subject: Reply with quote
it seems that this statement does not support {}. I will change that.
you can also specify the byte value : Replacechars Stemp , "d" , 255
