How to pass the table name to the SUB?
mrak
PostPosted: Fri Oct 17, 2014 7:03 am    Post subject: How to pass the table name to the SUB? Reply with quote
Dear all,
I would like to pass the name of the data table to the sub SUB in order to use it insight as an argument of the LOOKUP function.
Have tried to use the bylabel attribute as illustrated below:
call Procedure_name(data_table)
sub Procedure_name(bylabel my_label as word)
    xx=lookup(yy,my_label))
End Sub
Data_table:
Data 1, 2, 3, ...
But this approach is not accepted by the compiler.
Very appreciate an exemplary working code or your suggestion how to do this in the right way.
Thanks,
makarak
[/b]
PostPosted: Fri Oct 17, 2014 9:34 am    Post subject: Reply with quote
Test this in simulator Smile
$sim
$regfile = "m8def.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 64
$framesize = 64
Dim Address As Word
Dim N As Byte
Dim Items(5) As Byte
Declare Sub Show_array(byval Address As Word , Byval Linia As Byte)
Cls
Address = Loadlabel(label_1)
Call Show_array(address , 1)
Address = Loadlabel(label_2)
Call Show_array(address , 2)
'** pro forma
nop
'** End **
  Locate Linia , 1
  Loadadr Address , X
   !LD    R8,X+
   !LD    R9,X
    For N = 1 To 5
     Read Items(n)
     Lcd Items(n) ; " "
End Sub
Label_1:
Data 1 , 2 , 3 , 4 , 5
Label_2:
Data 5 , 4 , 3 , 2 , 1
Have a nice day
mrak
PostPosted: Mon Nov 03, 2014 9:32 pm    Post subject: Reply with quote
EDC,
thank you for your great suggestion plus the exemplary code enclosed
In the next step, after accessing the right table using a pair of the R8/R9 registers. I would like to jump over to an OFFSET position in the table. I have used the following code to achieve that:
Dim Bh As Byte , Bl As Byte                                 'auxiliary global variable used at offset calculation
Dim Font As Word
Dim Dw As Word                                              'address in the table
Sub Put_char(byval Font As Word , Byval Page As Byte , Byval Column As Byte , Byval Znak As String )
'locate the pointer address
   Loadadr Font , X
   !LD    R8,X+
   !LD    R9,X
   !sts {bl},r8
   !sts {bh},r9
   Ww = Makeint(bl , Bh)
   ww = ww + offset         'calculate the pointer address with offset
   'load the new pointer to the R8/R9 pair
   Bl = Low(offset)
   Bh = High(offset)
   !lds r8,{bl}
   !lds r9,{bh}
end sub
The above code works fine in line with expectations once the 'bl' and 'bh' are defined as a GLOBAL variables!
As soon as I try to define them as the LOCAL variables the compiler issues the following error: "No more space for BIT [BL]", "No more space for BIT [BH]"
Likely I misuse assembler command to store the R8/R9 register values to the local BH/BL variables hence the error.
Very appreciate your suggestion how to copy R8/R9 value into the local variable and (after adding the offset) copy back to these registers.
Please, note I hardly know assembler so any exemplary code will be more than welcome.
local BH/BL --> R8/R9 (what assembler code?)
R8/R9 --> local R8/R9 (what assembler code?)
Thank you in advance for any advice.
laborratte
PostPosted: Mon Nov 03, 2014 11:07 pm    Post subject: Reply with quote
Don't make your life harder than it should be. Locals are stored on the soft stack and so they have to accessed indirect via Y-register. See help "BASCOM Language Fundamentals > Mixing ASM and BASIC > Locals".
Just reserve global two bytes of RAM and be happy.
PostPosted: Mon Nov 03, 2014 11:12 pm    Post subject: Reply with quote
I don`t know where the problem. Offset can be set in many ways. Try Both codes try in symulator.
$sim
$crystal = 16000000
$hwstack = 64
$swstack = 64
$framesize = 64
Dim Address As Word
Dim N As Byte
Dim Offset As Word
Offset = 2                                                  'TRY OTHER VALUES
Cls
Macro Restore_address
   Loadadr Address , X                                      'restore address
   !LD    R8,X+
   !LD    R9,X
End Macro
'** pro forma
nop
'** End **
  Locate Linia , 1
  Address = Address + Offset
     Restore_address                                        'macro is used
    For N = 1 To 5
     Read Items(n)
     Lcd Items(n) ; " "
End Sub
Label_1:
Data 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9
Then second
$sim
$crystal = 16000000
$hwstack = 64
$swstack = 64
$framesize = 64
Dim Address As Word
Dim N As Word
Declare Sub Show_array(byval Address As Word , Byval Linia As Byte , Byval Offset As Word)
Cls
Call Show_array(address , 1 , 1)
   !LD    R8,X+
   !LD    R9,X
End Macro
'** pro forma
nop
'** End **
Sub Show_array(byval Address As Word , Byval Linia As Byte , Byval Offset As Word )
     Locate Linia , 1
    For N = 2 To 6
     Read Items(n)
     Lcd Items(n) ; " "
    Linia = Linia + Offset
    Locate Linia , 1
    Restore_address
    For N = 2 To 6
     Read Items(n)
     Lcd Items(n) ; " "
End Sub
Label_1:
If You want polish then click GG3100706
