Problem with comercial i2cslave library from MCS
Carlos
PostPosted: Sat Oct 18, 2014 3:08 pm    Post subject: Problem with comercial i2cslave library from MCS Reply with quote
Hello!
I use the new Version of I2C-Slave-lib:
comment = BASCOM-AVR USI I2C slave library
libversion = 2.0.7.7
date = 8 Jan 2014
I want to use an ATTiny2313 as a Slave and therefore used the following Code (having copied the *.Lib-Files to BASCOM/LIB !):
$regfile = "attiny2313.dat"
$crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 24
config USI = twislave , address = &H40
This results in the following compiler-error (BASCOM 2077):
Unknown CONFIG parameter [USI]
Unknown CONFIG parameter [ADDress]
I'd appreciate if someone could give me some pointers towards the problems in my code.
Thanks in advance
Ernst
Plons
PostPosted: Sat Oct 18, 2014 4:52 pm    Post subject: Reply with quote
You need to include the I2C library in your code. See Help file on how to use include
Bascom AVR ver 2.0.8.6
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel"
Carlos
PostPosted: Sun Oct 19, 2014 8:33 am    Post subject: Reply with quote
thank you, the cause was:
I must update the BASCOM Compiler from 2077 Build 2 to 2077 Build 4
problem solved!
Ernst
