Posted: Wed Oct 15, 2014 9:09 pm Post subject: Atemu / AT_emulator.lib
i bought the PS2 emulator Library a while ago and sucessfully developed some Keyboard devices with it (using USB/PS2 converters).
I now want to use the Keyboard Status LEDs but i cant find any information if or how they are implemented.
Is it possible to use the status LEDs (Nun, cab,roll)?
I am not sure what you want. the ps2 emulator allows you to emulate a keyboard. Thus, you have some switches and a micro that will behave like a normal ps/2 keyboard.
But from your question i understand that you want to light up the leds from a normal keyboard.
Or do you mean that you want to add a led to your circuit and use that as num lock indicator?
Or did you use a normal keyboard and and the emulator? _________________ Mark
in the past i used Atmegas as a Keyboard replacement. Now i need the 3 status leds for another project.
In the meantime i took a look into the AT_simulator lib an there are no routines for the LEDs in the lib.
Seems i have to change the lib and add a few lines for the LED. Should not be a big problem.
Are there other informations for .lib writing than in the help files? I would like to expand the Config Atemu line for the additional LEDS settings but dont know under which variable the settings from the config line appear in the .lib.
So i you want to control the leds of a keyboard.
Getatkbd and getatkbdraw can be used to communicate with a keyboard. ( to process key presses ). What you need to add is code that will send data to the keyboard.
About libs : you can not expand config commands since these are processed by the compiler.
A safe way to experiment with libs is by making a copy of the lib for example copy the lib file to : myExperiment.lib
then include the lib in the code with $lib "myExperiment.lib"
The compiler will find this lib first and use the code from this lib.
The libs contain atmel asm. There are some extensions. Have a look at the mcs.lib and other libs. _________________ Mark
