Stepper motor driver
snow
PostPosted: Sun Nov 20, 2005 9:12 am    Post subject: Stepper motor driver Reply with quote
Howdy All
I'm looking at making a CNC mini engraver. I was woundering if any one has done anything with stepper motor drives using a bipolar stepper motor. I want to use this type as the torque figures are pretty good and i have some lying around. I will be using step and direction form my PC parallel port. and using an avr 8535 for the interface driver.
Any pointers would be welcome.
Cheers
Snow
Luciano
PostPosted: Sun Nov 20, 2005 9:47 am    Post subject: Reply with quote
Stepper power board based upon L6208 circuit:
Stepper bipolar command (4 wires)
Maximum current 2.5A per phase
Mode : 1/2 step (Or full step, see pin 12).
Bridge control : 'Slow decay' (see datasheets)
Command Step/direction
Power supply unstabilised, but rectified and filtered, maximum 32V
Power supply stabilised, maximum 40V.
http://www.otocoup.com/CarteL6208_e.htm#Specif
Same but from Italy:
http://www.robotfactory.it/CncBoard/StepperBoard.htm
Schematic: (English)
http://www.robotfactory.it/CncBoard/Schema_board_P.jpg
Some notes:
- The L6208 has indipendent Signal and Power Ground.
- Beware to never shutdown the signal power supply (+ 5V) before
the stepper power supply, that will destroy power circuits.
- Cooling fan mandatory.
Best regards,
Luciano
snow
PostPosted: Sun Nov 20, 2005 8:10 pm    Post subject: Reply with quote
Thanks Mate, will look into it Very Happy
PostPosted: Sun Nov 20, 2005 9:14 pm    Post subject: Reply with quote
hi,
a module of system "Extralink" is very powerfull, speed, acceleration, step counter, switch of end,
another one is DC motor with encoder
They are available :
[url]www.sidena.com [/url]
Regards
JP
robpar
PostPosted: Mon Nov 21, 2005 5:24 am    Post subject: Reply with quote
I have used a motor controller from Gecko, their web site is http://www.geckodrive.com/. This uses step and direction and
will do multi stepping etc.
I am using their products to control my telescope motors with great success. In my research there were a number of people using these controllers for CNC conversions. They use simple step and direction input and have models for both stepper and servo systems. Give them a look they are reasonably priced.
Bob Parry
bzijlstra
Bascom Ambassador
PostPosted: Mon Nov 21, 2005 9:20 am    Post subject: CNC... Reply with quote
Have a look at http://members.home.nl/bzijlstra/hardware/stepper/stepper.htm
at the bottom.....
We are working on the PCB's and the software in Bascom-AVR now.
Have fun
Ben Zijlstra
