HX711 ADC 24 bits
hapra
PostPosted: Mon Oct 13, 2014 6:30 pm    Post subject: HX711 ADC 24 bits Reply with quote
Hi all,
I hope my question is really new about Chip HX711 ADC 24 bits, in this forum.
I am using ATmega32 MCU with crystal 4Mhz to communicate with HX711 Dual-Channel Weighing Sensor Module, this module image can be found on the internet.
While the HX711 datasheet in http://www.dfrobot.com/image/data/SEN0160/hx711_english.pdf
I am trying to convert from C (page 8th) to Bascom code, but it does not work at all even timing clock is set with different timing.
It means the return value is always 0 (zero).
Can anyone help me, may have a code that has been successfully working?
Thank you in advance.
Original code:
//*** C Coding ********************************************
sbit ADDO = P1^5;
sbit ADSK = P0^0;
unsigned long ReadCount(void){
unsigned long Count;
unsigned char i;
  ADDO=1;
  ADSK=0;
  Count=0;
  while(ADDO);
  for (i=0;i<24;i++){
    ADSK=1;
    Count=Count<<1;
    ADSK=0;
    if(ADDO) Count++;
  ADSK=1;
  Count=Count^0x800000;
  ADSK=0;
  return(Count);
My snippet code conversion:
'*** Bascom *********************************************
Adsk Alias Portd.4                                          'I use pin D.4 as output Clock
Addo Alias Portd.5                                          'I use pin D.5 as input Databit
Config Adsk = Output
Config Addo = Input
Dim Count As Long
Function HX711_Read() As Long
Local I As Byte
  'ADDO = 1               'I also give quotation marks at this alternately coz as input, not output
  Adsk = 0                                                  'clock LOW
  Count = 0                                                 'reset variable
  While Addo = 1                                            'wait until data ready
  Wend
  'Shiftin ADDO , ADSK , Count , 1 , 24 , 10     --> similar ?
  For I = 1 To 24                                           'channel A, gain 128x
    Adsk = 1                                                'clock HIGH
    Shift Count , Left , 1                                  'shift to left 1 bit
    Adsk = 0                                                'clock LOW
    If Addo = 1 Then Incr Count                             'give bit 1 for LSB, otherwise 0
  Count = Count Xor &H800000                                '0x800000
  Adsk = 0                                                  'clock LOW
  Hx711_read = Count                                        'returned value
End Function
(BASCOM-AVR version : 2.0.7.3 , Latest : 2.0.7.7 )
Evert :-)
PostPosted: Mon Oct 13, 2014 8:21 pm    Post subject: Reply with quote
Try
Addo Alias Pind.5                                          'I use pin D.5 as input Databit
Dibor
PostPosted: Tue Oct 14, 2014 11:27 am    Post subject: Reply with quote
Also instead Long use Dword because in C code used unsigned Long(Bascom doesn't has unsigned) so Dword is 32 bit unsigned variable as unsigned Long in C
But if you get value less then 32bit (24 bit for example)you do not need make any changes
Regards.
View user's profile MSN Messenger
hapra
PostPosted: Tue Oct 14, 2014 6:49 pm    Post subject: Reply with quote
Hi Evert,
Yes, your suggestion correctly, I had to type Pind.5 not Portd.5
Why I always forget about Portx.y for output bit assignment and Pinx.y for input bit assignment Rolling Eyes
Thank you very much for the correction.
Hi Dibor,
I look at Bascom AVR Help, there is no Dword, but when I try to compile the result is successful, I just realize that Dword actually already supported.
And currently I am still using 24-bits only for this purpose.
Thank you for the very useful information.
PostPosted: Sat Oct 18, 2014 2:27 pm    Post subject: Reply with quote
good work !
when you finish it, it would be nice to share your work with other bascom's users in "Share your working BASCOM-AVR code here"
many thanks
JP Wink
PostPosted: Tue Oct 21, 2014 9:57 pm    Post subject: Reply with quote
Actually it is mentioned in the language Fundamentals section.
