SPI slave IRQ doesn't work
Rahalph
PostPosted: Wed Oct 08, 2014 7:56 pm    Post subject: SPI slave IRQ doesn't work Reply with quote
Hello everybody,
I want to connect 2 atMega168 using SPI. I've connected GND and PB3..5 pins (MOSI/MOSI/SCK) directly (no cross over!).
I took the sample code for the slave, but the slave will never receive any data. The ISR is never triggered.
Anybody help, please?
Thanks
Ralph
Code for the master:
$regfile = "M168DEF.DAT"        ' atMEGA168
$crystal = 8000000        ' 8 MHz Takt
Config Portb.3 = Output        ' MOSI
Config Portb.4 = Input        ' MISO
Config Portb.5 = Output        ' SCK (8MHz / 128 = 62.5kHz)
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 1
Spiinit
Dim A(1) As Byte
A(1) = 42
  Wait 1
  Spiout A(1) , 1
Code for the slave:
$baud = 115200
Config Pinb.3 = Input        ' MOSI
Config Pinb.4 = Output        ' MISO
Config Pinb.5 = Input        ' SCK
Config Spi = Hard , Interrupt = On , Data Order = Msb , Master = No , Polarity = Low , Phase = 0 , Clockrate = 128
Spiinit
On Spi Spi_isr Nosave        ' specify the SPI interrupt
Enable Spi        ' enable spi interrupt
Enable Interrupts        ' enable global interrupts
Dim B As Byte , Rbit As Bit , Bsend As Byte
Print "start"        ' show that we started
Spdr = 0        ' start with sending 0 the first time
  If Rbit = 1 Then        ' when data received
    Print B        ' print it
    Reset Rbit        ' wait for more data
    Bsend = Bsend + 1
    Spdr = Bsend        ' increase SPDR
' Interrupt routine
Spi_isr:
  push r24        ' save used register
  in r24, sreg        ' save SREG
  push r24
  B = Spdr        ' Load data
  Set Rbit        ' we received something
  pop r24
  !out sreg, r24        ' restore SREG
  pop r24        ' and the used register
laborratte
PostPosted: Thu Oct 09, 2014 1:17 pm    Post subject: Reply with quote
a) you need to use the /SS pin for INT-driven SPI slave (see Datasheet)
b) you should not use "NOSAVE" if you plan to use BASCOM-Statements in your ISR. You can never be shure what registers your BASCOM statements are using and that the register usage will remain the same after a BASCOM update or when changing the controller type.
c) you should not use BIT vars in isr for flags, use BYTE instead. Otherwise you need to encapsulate every use of every BITVAR in main loop like
disable interrupts
if BITVAR = 1 then
  BITVAR = 0
end if
enable interrupts
because other BIT vars can be corrupted by the isr.
