XMEGA External Cristal not work in 2.0.7.7
barni7
PostPosted: Sun Oct 05, 2014 8:09 pm    Post subject: XMEGA External Cristal not work in 2.0.7.7 Reply with quote
I have use a cristal with 8 MHz in Version 2.0.7.6.
This code works fine.
Now in Version 2.0.7.7 it's dont work.
$crystal = 32000000                                         ' xmega128 is running on 32 MHz
$regfile = "xm128a1def.dat"
$lib "xmega.lib"                                            ' add a reference to this lib
$loader = &H10000
'configure the systemclock
Config Osc = Disabled , Extosc = Enabled , Range = 2mhz_9mhz , Startup = Xtal_256clk
'Set the Multiplication factor and select the clock Reference for the PLL
Cpu_ccp = &HD8
Osc_pllctrl = &B11_0_00100                               ' EXTERNAL clock Source and Multiplication factor = 4
Bitwait Osc_status.3 , Set                               'Check if XOSCRDY is ready
Set Osc_ctrl.4                                           ' PLL enable
PostPosted: Sun Oct 05, 2014 9:14 pm    Post subject: Reply with quote
when you change : Config Osc = Disabled to Config Osc = ENABLED it will work as before.
In 2077 there is a check on the oscillator status bits that are enabled, but since the internal osc will return a 1 as well, the code keeps checking. So the solution is to enable this bit so it will be part of the test.
In the next update this bit is AND-ed when not used so this work around is not required any more.
