XMEGA Timer and Port Config
enniom
PostPosted: Mon Oct 06, 2014 1:31 am    Post subject: XMEGA Timer and Port Config Reply with quote
Hello,
I'm in the midst of developing an small application and do not have a way to test the question below:
Imagine the first Timer in PORTE is defined as a timer with an ISR:
Config Tce0 = Normal , Prescale = 1024 , Resolution = Normal
Tce0_per = &H1E                                             ' period register
On Tce0_ovf Wait_timer_isr
Enable Tce0_ovf , Lo
Question: can PORTE.0 (or the other PORTs E1..E3 associated with this Timer) be configured as INPUT or OUTPUT?
For example:
Config PortE.0 =Output
PortE.0 = 1
Tiny
PostPosted: Mon Oct 06, 2014 5:59 am    Post subject: Reply with quote
dear enniom
Yes you can use de i/o pin on porte for example general i/o
regards Tiny
enniom
PostPosted: Mon Oct 06, 2014 11:29 am    Post subject: Reply with quote
Thanks tiny for your help.
