Errors in sample file "capture.bas"
DJ7DA
PostPosted: Sun Oct 05, 2014 6:54 pm    Post subject: Errors in sample file "capture.bas" Reply with quote
Hello dear reader,
upon diving into the mysteries of timers once again, I loaded capture.bas from the sample files.
The code explorer immediately showed 4 Errors, all in the "Config Timer1...." line.
The programm seems to be performing as expected, though.
Can I simply disregard these errors, or is there some hidden trap?
Thank you
Ernst
PostPosted: Sun Oct 05, 2014 9:10 pm    Post subject: Reply with quote
you can ignore these 'errors'. Please read what i wrote in the help. 'view code explorer' : In version 2.0.7.7 the code explorer is considered a beta functionality.
and related to show errors :
Show Errors
This option deserves a warning. The option is turned off by default. It can be useful to find errors but it can also point to errors which are not considered an error for the compiler. The compiler has a separate parser. The parser from the IDE is a different new parser. When the definition files are fully updated, the errors shown will be similar to the errors the compiler will report. At the moment of updating the help, the reported errors are mostly errors caused by missing CONFIG definitions. The reason this option is included is that it can prove to be very useful in some cases. So in short, only the errors reported by the compiler count and the errors reported by the IDE can be used to fix errors while you edit.
DJ7DA
PostPosted: Sun Oct 05, 2014 9:55 pm    Post subject: Reply with quote
Thank you for your prompt response Mark. I apologize for not having read the relevant text.
Best regards
Ernst
