Tektronix 4010(4014) graphic terminal (emulator) library
O-Family
PostPosted: Fri Oct 03, 2014 2:23 am    Post subject: Tektronix 4010(4014) graphic terminal (emulator) library Reply with quote
Tektronix 4010 (4014) is a computer graphics terminal of an old time.
Catalog: Tektronix 4010 Computer Display Terminal
Terminal emulator software "Tera Term" has a TEK4010 (4014) terminal emulation function.
BASCOM makes a graph draw to a personal computer using this function.
It connects by "RS-232C" or "USB-serial conversion" using UART of AVR.
Since the Arduino board carries "USB-serial conversion", the addition of an option is unnecessary.
AVR obtains the display screen of high resolution, and acquires the capability to print(Hard copy) it with a printer!
Computer screen Hard copy
1.Download and install the latest version of "Tera Term" from "SourceForge.jp".
2.[Setup] -> [Serial port] -> "Serial port setup" dialog box.Set the baud rate.
3.[Setup] -> [Terminal] -> "Terminal setup" dialog box. Enable the "Auto switch (VT<->TEK)".
4.[Control] -> [Open TEK] -> Opens the TEK window.
[Setup] -> [Font] -> "Font" dialog box. Font size is changed into any value. (Example: Size 16)
5.[Setup] -> [Window] -> "Window setup" dialog box. The color of "Text" and "Background" is changeable.
6.[VT-window] -> Return to the "VT-window".
[Setup] -> [Save setup] -> "Save setup" dialog box. Save the settings.
   '  *  Tektronix 4010(4014) Graphic Terminal Library  *
   '  *                       O-Family   2014. 9.29     *
$regfile = "m88pdef.dat"                                    'Any chip.
$crystal = 16000000                                         'Any frequency.
$hwstack = 64
$swstack = 32
$framesize = 24
$baud = 9600                                                'Set the baud rate.
'--------- Include a control instruction of TEK4010. ---------
Dim _temptx As Byte                                         'Internal variables of the library.
_temptx = &H1F : Printbin _temptx                           '[US] Changes Terminal to Alpha Mode.
$lib "TEK4010emu.lib"                                       'Tektronix 4010(4014) graphic terminal (emulator) library.
$external Tekcls , Tekline , Tekbox , Tekpset , Teklocate , Tekgraph , Tekalpha , Tekplot
Declare Sub Tekcls : Declare Sub Tekalpha : Declare Sub Teklocate(byval _tekx0 As Word , Byval _teky0 As Word)
Declare Sub Tekline(byval _tekx0 As Word , Byval _teky0 As Word , Byval _tekx1 As Word , Byval _teky1 As Word , Byval _tekvt As Byte)
Declare Sub Tekbox(byval _tekx0 As Word , Byval _teky0 As Word , Byval _tekx1 As Word , Byval _teky1 As Word , Byval _tekvt As Byte)
Declare Sub Tekpset(byval _tekx0 As Word , Byval _teky0 As Word)
Declare Sub Tekgraph(byval _tekvt As Byte) : Declare Sub Tekplot(byval _tekx0 As Word , Byval _teky0 As Word)
   ' Tekcls  <Clear the Vector and Alpha Screen.>
   ' Tekline X(start) , Y(start) , X(end) , Y(end) , Vector-Type  [X = 0 - 1023 , Y = 0 - 778 , Vector-Type = 0 - 23]  <Draws a line.>
   '         [Vector-Type = 0:normal line , 1:dotted line , 2:dot-dashed , 3:short-dashed , 4:long-dashed]
   ' Tekbox X(left corner) , Y(top position) , X(right corner) , Y(bottom position) , Vector-Type  <Write a box.>
   ' Tekpset X(location) , Y(location)  [X = 0 - 1023 , Y = 0 - 778]  <Set a single pixel.>
   ' Teklocate X(location) , Y(location)  [X = 0 - 1023 , Y = 0 - 778]  <Moves the Alpha cursor to the specified position.>
   ' Tekgraph Vector-Type  [Vector-Type = 0 - 23]  <Sets Terminal to Graph Mode , Select the vector type.>
   ' Tekplot X(location) , Y(location)  [X = 0 - 1023 , Y = 0 - 778]  <Plot the graph line.>  Note: Perform Tekgraph.
   ' Tekalpha  <Terminal is returned to alpha mode.>
   ' * Drawing test program *
   Dim W1 As Word , W2 As Word , W3 As Word , S1 As Single , S2 As Single , B As Byte
   Tekcls                                                   'Clear the Vector and Alpha Screen.
   Print "Tektronix 4010(4014) graphic terminal (emulator)"
   Tekline 0 , 0 , 1023 , 0 , 1                             'Outer frame.
   Tekline 1023 , 0 , 1023 , 778 , 1
   Tekline 1023 , 778 , 0 , 778 , 1
   Tekline 0 , 778 , 0 , 0 , 1
   Tekline 0 , 430 , 1023 , 430 , 0                         'Vector Type.
   Tekline 0 , 420 , 1023 , 420 , 1
   Tekline 0 , 410 , 1023 , 410 , 2
   Tekline 0 , 400 , 1023 , 400 , 3
   Tekline 0 , 390 , 1023 , 390 , 5
   Teklocate 900 , 388                                      'Moves the Alpha cursor.
   Print "Vector Type"
   For W1 = 448 To 778 Step 10                              'Slanting line.
      Tekline 0 , 448 , 1023 , W1 , 0
   Next W1
   Tekbox 80 , 720 , 280 , 580 , 1                          'Write a box.
   Tekbox 100 , 700 , 200 , 600 , 0
   Teklocate 134 , 638                                      'Moves the Alpha cursor.
   Print "BOX"
   Tekline 30 , 195 , 390 , 195 , 1                         'Scale line.
   Tekline 30 , 45 , 30 , 345 , 0
   For W1 = 0 To 360                                        'Sign waveform.
      S1 = W1
      S1 = Deg2rad(s1)
      S1 = Sin(s1)
      S1 = S1 * 150
      S1 = S1 + 195
      W2 = Int(s1)
      W3 = W1 + 30
      Tekpset W3 , W2                                       'Set a single pixel.
   Next W1
   Teklocate 240 , 270                                      'Moves the Alpha cursor.
   Print "Sign Wave"
   Tekline 450 , 195 , 710 , 195 , 3                        'Scale line.
   Tekline 580 , 65 , 580 , 325 , 3
   For W1 = 0 To 360                                        'Circle.
      S1 = W1
      S1 = Deg2rad(s1)
      S2 = Cos(s1)
      S1 = Sin(s1)
      S1 = S1 * 120
      S1 = S1 + 195
      W2 = Int(s1)
      S2 = S2 * 120
      S2 = S2 + 580
      W3 = Int(s2)
   Next W1
   Teklocate 500 , 230                                      'Moves the Alpha cursor.
   Print "Circle"
   Tekline 770 , 80 , 1000 , 80 , 0                         'Scale line.
   Tekline 770 , 80 , 770 , 310 , 0
   Restore Graphdata                                        'Drawing a graph.
   W1 = 770                                                 'X position.
   Tekgraph 1                                               'Sets Terminal to Graph Mode , Select the vector type.
   For B = 1 To 5
      Read W2
      Tekplot W1 , W2                                       'Plot the graph line.
      W1 = W1 + 50
   Next B
   Tekalpha                                                 'Terminal is returned to alpha mode.
   Teklocate 860 , 280                                      'Moves the Alpha cursor.
   Print "Graph"
   Teklocate 50 , 520                                       'Moves the Alpha cursor.
   Print "END"
Graphdata:
   Data 120% , 220% , 250% , 150% , 180%                    'Graph data.
Coordinate
By changing a part of embedded program and library, software UART can also be used for AVR without UART.
"Printbin" -> "Printbin #1"
PostPosted: Fri Oct 03, 2014 10:44 am    Post subject: Reply with quote
Hello O-Family,
great nostalgic application Very Happy
It was nice to read the brochure. $3500 for a terminal, wow !
Your lib is a good example for a serial based display.
Because of the emulator it is simple to try.
Thanks for sharing.
O-Family
PostPosted: Wed Jan 07, 2015 2:21 am    Post subject: Reply with quote
The above was corresponds to 4010 (4014) of monochrome display.
"Tera Term" also corresponds to 410x of color display.
Therefore, I added the "Tekcolor" command for specifying the drawing color.
Computer screen
5.[Setup] -> [Window] -> "Window setup" dialog box. Enable the "Color emulation".
Background color, you can change by "Reverse" button.
   '  *  Tektronix 4010(4014,410x) Graphic Terminal Library  *
   '  *            [Ver.2]         O-Family   2015. 1. 5     *
$hwstack = 64
$swstack = 32
$framesize = 24
$lib "TEK4010emu.lib"                                       'Tektronix 4010(4014,410x) graphic terminal (emulator) library.
$external Tekcls , Tekline , Tekbox , Tekpset , Teklocate , Tekgraph , Tekalpha , Tekplot , Tekcolor
Declare Sub Tekpset(byval _tekx0 As Word , Byval _teky0 As Word) : Declare Sub Tekcolor(byval _tekcol As Byte)
   ' Tekcolor Color  [0 = Black, 1 = Red, 2 = Green, 3 = Yellow, 4 = Blue, 5 = Magenta, 6 = Cyan, 7 = White]  <Set a color of the drawing.>
   Tekcolor 7                                               'Drawing color [white].
   Print "Tektronix 4010(4014,410x) graphic terminal (emulator)"
   Tekcolor 1                                               'Drawing color [Red].
   Tekbox 0 , 0 , 1023 , 778 , 1                            'Outer frame.
   Tekcolor 2                                               'Drawing color [Green].
   Tekcolor 7                                               'Drawing color [White].
   Print "Vector Type"
   Tekcolor 4                                               'Drawing color [Blue].
   W1 = 448
   For B = 1 To 34                                          'Slanting line.
      W1 = W1 + 10
   Next B
   Tekcolor 3                                               'Drawing color [Yellow].
   Print "BOX"
   Tekcolor 5                                               'Drawing color [Magenta].
      S1 = W1
      S1 = Deg2rad(s1)
      S1 = Sin(s1)
      S1 = S1 * 150
      S1 = S1 + 195
      W2 = Int(s1)
      W3 = W1 + 30
   Next W1
   Print "Sign Wave"
   Tekcolor 6                                               'Drawing color [Cyan].
      S1 = W1
      S1 = Deg2rad(s1)
      S2 = Cos(s1)
      S1 = Sin(s1)
      S1 = S1 * 120
      S1 = S1 + 195
      W2 = Int(s1)
      S2 = S2 * 120
      S2 = S2 + 580
      W3 = Int(s2)
   Next W1
   Print "Circle"
   For B = 1 To 5
      Read W2
      W1 = W1 + 50
   Next B
   Print "Graph"
   Print "END"
Graphdata:
rredding
PostPosted: Sat Feb 27, 2016 5:55 pm    Post subject: TEK 4010 Reply with quote
Wow! That brought back memories. When I was quite a bit younger I bought a 4010 terminal surplus for about $20 or $30 USD. I think I had to fix up the power supply to get it to work. Anyway, these were fun to watch since they work kind of like an oscilloscope with persistence. I remember writing a 4010 driver for a program I wrote. I was able to output 2D graphs and such. Anyway, thanks for sharing this.
Per Svensson
PostPosted: Mon Mar 21, 2016 10:42 am    Post subject: Reply with quote
This post reminded me that I have one of these old but faschinating A0-plotters from HP (the 7580 model) standing in a corner of the lab.
I remember that the price tag was USD15000 at the time (1985) so it still stand there. It is working but of no use.
Some day I will Power it up again and use it for something I yet have not figured out...
I wonder if some bascom-guy have written a driver for it? It is designed for HPGL so most commands are "standard" HPGL graphic commands.
Wathing this machine in full action is a true pleasure. Smile
/Per
Dave
PostPosted: Sun Jan 08, 2023 5:40 pm    Post subject: Reply with quote
Thank you O-Family for this lib. I was searching the web for a Tek4010 emulator and was surprised to end up here on the MCS forum. I didn't know that my favorite terminal program (tera term) had tek4010 emulation built in. I used one of these terminals way back in 1978 and 79 so for nostalgia I want to use this to display something. I've spent the last few days writing a rudimentary chart program that uses you lib. I've included a zip file with my demo and two Tek4010 user manuals. The demo shows how to get different fonts and how Gin mode can be used to display a cross-hair for user input.
I had to change one line of code in your lib file to get it to compile for AVRX processors:
At line 26 of the lib file:
'Comment out ---> ;*BASIC: Printbin _temptx 'Send to USART. *** REMOVED, WILL NOT COMPILE WITH MY COM CONFIG.
'Replace with --> *BASIC: Print #1, chr(_temptx); 'Send to USART. *** SAME THING USING PRINT.
I'm running at 38400 baud but with a few tricks it will plot at the fastest baud tera term will run at (921600 baud). If anyone is interested in plotting faster I'll share how I did that.
Also there is a beautiful Tek4010 emulator for Raspberry Pi. I had a Pi Zero laying around so I tried it and it works fine. That emulator simulates the 4010 in a much more realistic way.
Thanks again
Dave
