ADC Reference voltage
dongags5
PostPosted: Tue Sep 16, 2014 9:12 am    Post subject: ADC Reference voltage Reply with quote
I am unsure about the Reference voltage on the ATMEGA8535.
I use an inductor and capacitor from the VCC to supply the AVCC ADC pin and just use a bypass cap on the AREF pin and of course the ADC ground pin is grounded.
I use the following command
Config Adc = Single , Prescaler = Auto , Reference = Avcc
When I measure the voltage at the AREF pin I get the same voltage as I measure at the AVCC pin which is 5V which surprises me as I was expecting a reference voltage of 2.56V. Maybe what is measured at that pin is not the actual reference voltage?
I have an LCD display and look at the output from Getadc(2) i.e. the channel I use to apply an external voltage to the ADC.
Why is it that 255 (the maximum byte) is displayed when the DC input voltage is about 1.25V? I thought it would require an input voltage of twice that i.e. the same as the reference voltage (2.56V) or if the reference is 5V would be nearly twice that.
I hope that someone can throw some clarity on this - thanks.
Don
(BASCOM-AVR version : 2.0.7.5. , Latest : 2.0.7.7 )
Paulvk
PostPosted: Tue Sep 16, 2014 10:18 am    Post subject: Reply with quote
Hello Don
Config Adc = Single , Prescaler = Auto , Reference = Avcc <<<<<<< its working as expected you told it to use AVCC
Try
Config Adc = Single , Prescaler = Auto , Reference =INTERNAL_2.56
I do not have a 8535 to try
Regards Paul
Visovian
PostPosted: Tue Sep 16, 2014 3:18 pm    Post subject: Reply with quote
It seems like you are reading adc into a byte variable.
Maximum adc value = 1023. You need word variable.
Try
dim adc_val as word
adc_val = getadc(2)
Lcd adc_val
dongags5
PostPosted: Wed Sep 17, 2014 1:07 pm    Post subject: Reply with quote
Thanks Paul,
I don't understand why there needs to be a s/w directive to have the AVcc reference when simply connecting the hardware AVcc to the reference pin would do the same thing if the chip only has the AVcc reference option. I tried the internal_2.56 directive and the compiler doesn't come up with an error. I got the impression that the ATMEGA8535 only accepts the Reference= AVcc command. I didn't measure the voltage at the reference pin when the _2.56 was specified but I suppose it would not be brought out and may not even be 2.56V - will check when I have time.
Thanks Visovian, you are quite right but I don't need high accuracy so a byte variable is fine.
cheers
Don
Evert :-)
PostPosted: Wed Sep 17, 2014 8:55 pm    Post subject: Reply with quote
Is the correct way to 2.56V internally, the correct bits (REFS1 and REFS0) are set by Bascom. Tested in the simulator.
Are you using the correct regfile?
8535def.dat = for the AT90S8535
M8535.dat = for the Mega8535
Arera
PostPosted: Thu Sep 18, 2014 2:19 pm    Post subject: Reply with quote
Hi Don
You must use a word for the adc. A byte would not reduce accuracy, but lead to completely false results.
dongags5
PostPosted: Fri Sep 19, 2014 8:25 am    Post subject: Reply with quote
Thanks Evert, I am using the correct regfile M8535.dat
In the Bascom help file, for the 8535 chip there seems to be only 2 modes: OFF and AVCC but as Paul suggested earlier I can use the internal reference of 2.56V. I measured 2.56V at the AREF pin confirming it to be correct.
Thanks Arera, I restrict my maximum input level so that I can use the byte variable rather than word as the high byte is zero. (ADC Result Registers ADCL is only used). Results are as expected and with sufficient accuracy for the requirement.
cheers
Don
Smile
Arera
PostPosted: Fri Sep 19, 2014 8:30 am    Post subject: Reply with quote
OK, you know what you are doing!
I thought you expectet to decrease the ADC's resolution from 10 to 8 bit by using a Byte....
Deanus
PostPosted: Sat Sep 20, 2014 7:53 am    Post subject: Reply with quote
Hi dongags5,
With regards to the reference voltage, according to the data sheet,
You can choose the internal reference (2.56V) , OR the External reference VCC (Chip supply voltage) ,
But you CANNOT or should I say SHOULD NOT apply an external reference voltage and choose the internal reference via the switches.
This will have the effect of applying VCC chip supply voltage to the output of an opamp and will possibly destroy the internal reference opamp.
It explains it all in the Analogue reference section of the data sheet. Page 213 on my datasheet.
IF you supply an external Aref, then you MUST choose
Reference = Avcc
If you choose the internal 2.56V reference, then
and Nothing connected to Vref PIN except maybe a capacitor .[/quote]
See attached is a snippet from the sheet.
As far as reading the data, the number you read is NOT a voltage, it is the number which represents the input voltage divided by the the maximum number of digital bits that the ADC is set up for.
EG: 10bit is 1024 steps
Reading the number from the ADC will result in 1024 for 5V (or what ever you micro supply voltage is) down to 0 ( Zero )with NO input voltage.
512 for 2.5 Volts input etc.
Read page 218 ADC Conversion Result, this gives you the formula for reading the voltage correctly.
It's up to to convert it to the correct voltage.
Also remember, DO NOT apply a voltage greater than you micro supply voltage to the analog input. Even though it's analogue input, it is still only 0 to 5V ( or what ever you micro supply voltage is.)
Regards
Dean
