M128 problem
komisarios
PostPosted: Fri Sep 12, 2014 12:40 pm    Post subject: M128 problem Reply with quote
Hi there,
I run a demo version 2.0.7.3 on a M128 (fuse as M128-not M103) and i found a problem:
I use an input (pin 17) that when is connected to +5V , the lcd is supposed to write "OK"
But regardless the input if it is 0V or 5V , the mcu constantly prints OK.
'DDRB=&B00000000 (also tried that)
Config Pinb.7 = input
'Reset Portb.7 (also tried that)
Nop
Loop Until Pinb.7 = 1
Lcd "OK"
(BASCOM-AVR version : 2.0.7.3 , Latest : 2.0.7.7 )
six1
PostPosted: Fri Sep 12, 2014 6:05 pm    Post subject: Reply with quote
$regfile = "m128def.dat"
   $crystal = 8000000
   $hwstack = 16
   $swstack = 16
   $framesize = 16
Config Portb.7 = input
Portb.7 = 1 'Set Pullup
   if Pinb.7 = 1 then
     Lcd "1"
   else
     Lcd "0"
   end if
loop
For technical reasons, the signature is on the back of this message.
