I need help to update ps2 controller
mtm4elnagem
PostPosted: Wed Sep 10, 2014 10:45 am    Post subject: I need help to update ps2 controller Reply with quote
hi
i find code ps2 controller i wont to update code
to work at char LCD 2X16 and atmega32 crystal 8mhz
code must be when i press any key ps2 controller show name of key on lcd
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=8531&highlight=ps2
' Project:  PlayStationII Wireless (or wired) controller reader
' Version:  v1.0
' Created:  2010-03-27
' By:       Glen Aidukas   (C)Bahbots.com
' Credits:  Original help from Eddy Wright on the PS2 protocol
' Description:
'  PS2 Shockwave controller wiring and PSI data reading
'   _____________________________
'  | |1  2  3||4  5  6||7  8  9| |  <-- Male connector of controller
'   \___________________________/
'  Pin   Color    Function Notes
'  1     GREEN    MISO     Data In
'  2     WHITE    MOSI     Command out
'  3     VIBRATE  +9V
'  4     BLACK    GND
'  5     RED      VCC      3.3V-5V
'  6     BLUE     SS       Select
'  7     YELLOW   SCK      Clock
'  8     N/C      N/C
'  9     ACK      N/C
'  This code was tested and working with a wireless PlayStationII controller
$regfile = "m32Def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 16
$framesize = 48
$baud = 38400
'=====[ Dimension and initialize variables ]====================================
Dim Ps2_cmd(2) As Byte                                      ' init cmd sent to PS2 controller
Dim Ps2_data(7) As Byte                                     ' hold returned data from PS2 controller
Dim I As Byte                                               ' General purpose variables
Ps2_miso Alias Pinb.0 : Ddrb.0 = 0                          ' data in
Ps2_mosi Alias Portb.1 : Ddrb.1 = 1                         ' data out
Ps2_ss Alias Portb.2 : Ddrb.2 = 1                           ' Select
Ps2_sck Alias Portb.3 : Ddrb.3 = 1                          ' Clock
Ps2_miso = 1                                                ' turn on internal pull up resister
Ps2_cmd(1) = &H01                                           ' Start Command
Ps2_cmd(2) = &H42                                           ' Request Data
 Print "{027}[2J" ;                                         ' ansi clear screen...
 print "Starting..."
Cls
   Gosub Ps2_read                                           ' read the PS controller data
   print "{027}[3;1H";                                        ' move to page top (ansi)
   print "Byte1 : " ; Ps2_data(1) ; "  "
   ''print ""
   print "Select: " ; Ps2_data(2).0 ; "     Start : " ; Ps2_data(2).3
   print "ThumbL: " ; Ps2_data(2).1 ; "     ThumbR: " ; Ps2_data(2).2
   ''print ""
   print "CNT-Up: " ; Ps2_data(2).4 ; "     CNT-R : " ; Ps2_data(2).5
   print "CNT-Dn: " ; Ps2_data(2).6 ; "     CNT-L : " ; Ps2_data(2).7
   'print ""
   print "L1    : " ; Ps2_data(3).2 ; "     R1    : " ; Ps2_data(3).3
   print "L2    : " ; Ps2_data(3).0 ; "     R2    : " ; Ps2_data(3).1
   ''print ""
   print "Triang: " ; Ps2_data(3).4 ; "     Cross : " ; Ps2_data(3).6
   print "Circle: " ; Ps2_data(3).5 ; "     Square: " ; Ps2_data(3).7
   ''print ""
   print "Joy RX: " ; Ps2_data(4) ; "  "
   print "Joy RY: " ; Ps2_data(5) ; "  "
   print "Joy LX: " ; Ps2_data(6) ; "  "
   print "Joy LY: " ; Ps2_data(7) ; "  "
   'waitms 100
'=====[ Read the PS2 controller data ]==========================================
Ps2_read:
   Ps2_ss = 0                                               ' assert select line
   Shiftout Ps2_mosi , Ps2_sck , Ps2_cmd(1) , 2 , 8 , 20    ' send start command
   Shiftout Ps2_mosi , Ps2_sck , Ps2_cmd(2) , 2 , 8 , 20    ' send request data cmd
   For I = 1 To 7
    Shiftin Ps2_miso , Ps2_sck , Ps2_data(i) , 2 , 8 , 20   ' read in data
   Next I
  Ps2_ss = 1                                                ' release select line
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.7 )
