drejansen
Joined: 10 Jun 2006 Posts: 26 Location: Hoeksche Waard
Posted: Thu Sep 25, 2014 1:01 pm Post subject: Windows 8.1 Arduino en Bascom |
Geacht Forum, (English below)
Ik had problemen met de communicatie tussen Bascom en Arduino.
Nadat ik WINAVR had geinstalleerd werkte het wel.
Volgens Mark heeft dat er niets mee te maken, dus zou het zonder ook moeten werken.
Niet geschoten is zeker mis.
WINAVR kan je downloaden van http://sourceforge.net/projects/winavr/files/latest/download?source=files
Na installeren hoef je er niet meer naar om te kijken, wel even de PC opnieuw starten.
Suc6, groeten, Dré
Dear forum,
I had problems with the communication between Arduino and Bascom.
After I installed WINAVR the problem was solved.
Mark says it has nothing to do with WINAVR, it has to work without it.
But in my case, it works now and I am happy.
If you like to try it, you can download from http://sourceforge.net/projects/winavr/files/latest/download?source=files
After installation, restart your PC and you have never to look at WINAVR again.
Greetings, Dré _________________ Pluk het moment!
een hele dag lukt toch niet.
Groeten, Dré Jansen
aphawk
Posted: Thu Sep 25, 2014 9:05 pm Post subject: |
I use Windows 7 and Windows XP.
I only needed install AVRDUDE to work with Bascom, as told in the WIKI.
But I tried many programmers options, like ARDUINO, and it don't works. My only working solution was using AVRDUDE.
Paulo |
Paulvk
Posted: Fri Sep 26, 2014 12:56 am Post subject: |
I am using windows 8 and the arduino mega2560 using just bascom ARDUINO STK500 V2
But I need a normal spi programmer to change fuses and eeprom
Regards Paul |
Posted: Wed Oct 29, 2014 9:59 am Post subject: |
Hello
I work on W7 and my wife has a W8.1.
I install Bascom on her computer, and I install Arduino software too.
I ran arduino first : no pb with the blink program
the pc recognize the Arduno serial port.
then I ran Bascom without any problem
Quote: | But I need a normal spi programmer to change fuses and eeprom | said Paul
that is true, it is impossible to play with the fuse from BAscom-Arduino programmer. but that is also true with Arduino IDE
jp  |
