Arduino Nano and PWM on a RGB-led
bzijlstra
Bascom Ambassador
PostPosted: Sun Sep 07, 2014 7:28 pm    Post subject: Arduino Nano and PWM on a RGB-led Reply with quote
No rocket-science but nice to show PWM testprogram for a RGB-led
The RGB-led on a PCB. R G B labeling not correct. But no problem.
Three different colors. In this example an ETT Arduino Nano compatible is used. With an Atmega168.
' PWM op Arduino Nano atmega168 with RGB led
$regfile = "m168def.dat"                                    ' specify the used micro
$crystal = 16000000                                         ' used crystal frequency
$hwstack = 32
$swstack = 32
$framesize = 32
$baud = 9600
Red_pwm Alias Pwm0a
Green_pwm Alias Pwm1a
Blue_pwm Alias Pwm2a
Config Timer0 = Pwm , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Config Timer1 = Pwm , Pwm = 8 , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Config Timer2 = Pwm , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Config Portb.3 = Output                                     'red
Config Portb.1 = Output                                     'green
Config Portd.6 = Output                                     'blue
Dim X As Byte
Print Chr(27) ; "[2J"                                       'ANSI CLS goto 0/0
Print "Arduino Nano Atmega168 RGB PWM Example"
Print
Red_pwm = 0
Green_pwm = 0
Blue_pwm = 0
Print
Print "test RED"
For X = 1 To 255
Red_pwm = X
Waitms 10
Next X
Red_pwm = 0
Print
Print "test GREEN"
For X = 1 To 255
Green_pwm = X
Waitms 10
Next X
Green_pwm = 0
Print
Print "test BLUE"
For X = 1 To 255
Blue_pwm = X
Waitms 10
Next X
Blue_pwm = 0
Print
Print "All RGB colors together"
For X = 1 To 255
Red_pwm = X
Green_pwm = X
Blue_pwm = X
Waitms 10
Next X
Red_pwm = 0
Green_pwm = 0
Blue_pwm = 0
Print
Input "Give PWM value for RED   (0 - 255) " , X
Red_pwm = X
Print
Input "Give PWM value for GREEN (0 - 255) " , X
Green_pwm = X
Print
Input "Give PWM value for BLUE  (0 - 255) " , X
Blue_pwm = X
Print
Three separate timers are used.
And here the images on a mini-scope
PWM 50 and PWM 200 used.
Have fun
Ben Zijlstra
PostPosted: Mon Sep 08, 2014 3:28 pm    Post subject: Reply with quote
good !
I use it with the lcd display 16*2 from DFrobot , the light is drived by a PWM:
Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7 , E = Portb.1 , Rs = Portb.0
Config Lcd = 16 * 2
Config Pinb.2 = Output ' Timer 1 for PWM
Config Timer1 = Pwm , Pwm = 10 , Prescale = 1 , Compare B Pwm = Clear Up
'the output for PWM1 is PB1 (OC1A) and PB2 (OC1B) here we use OC1B
Pwm1b = 200 'you can change the light by increasing or decreasing it, max 255
many thanks
JP Wink
