DDS AD9850 Controller for Arduino LCD Keypad Shield.
O-Family
PostPosted: Fri Mar 13, 2020 8:13 am    Post subject: DDS AD9850 Controller for Arduino LCD Keypad Shield. Reply with quote
Analog Devices AD9850 is controlled by Arduino LCD Keypad Shield.
The frequency can be set in units of 0.1 Hz.
(There is an error because the resolution of DDS is about 0.0291Hz)
99 memories that can store frequency values.
If there is an error in the crystal oscillator of the reference clock [REFCLOCK], the output error will increase, so it can be calibrated in the program.
Circuit diagram
https://drive.google.com/open?id=10U4sUa9p335aCx6dbIsFtgErKVlQ-Zsj
Operate using the character LCD and key switch mounted on the “LCD Keypad Shield” board.
Move the setting cursor displayed at the bottom of the LCD to set the output item and frequency.
The operation method of the key switch is described in the following "Operation Manual".
https://drive.google.com/open?id=1HDPde3msHRSKAV8vAlpGJY3BZ42kbz9o
O-Family
PostPosted: Fri Mar 13, 2020 8:31 am    Post subject: DDS AD9851 Controller for Arduino LCD Keypad Shield. Reply with quote
Analog Devices AD9851 is controlled by Arduino LCD Keypad Shield.
(There is an error because the resolution of DDS is about 0.0419Hz)
Circuit diagram
https://drive.google.com/open?id=1ky3SJHm3-xxRSAszzpD47zRIwCKClsRZ
https://drive.google.com/open?id=17WvjFVk8p5ZdSGAbI6swx4zfyWolq4rw
PostPosted: Fri Mar 13, 2020 12:25 pm    Post subject: Reply with quote
Hello O-Family,
That is a great collection of DDS controllers projects you are sharing.
And as usual great quality with all details.
I appreciate the fact that you took time to translate into English and publish it.
great job!
