Posted: Fri Sep 05, 2014 8:12 am Post subject:
The i2c bootloader code is now finished. I left it running over night uploading various version of the main app/testing the functions in the slave and the upload ran 600times without any errors.
So, here's the code:-
Upload routine for the main CPU
'----------------------------------------------------------------------------- Sub Upload_firmware(byval I2c_address AsByte) 'Function : Send firmware image to uC 'Author : Ian Dobson 'Inputs : Write address of slave. 'Outputs : None 'Limitations : The pointer to the firmware to upload must be set before ' calling this routine (using restore) ' The firmware should be included using the $inc command with ' the size option. For example ' $inc Irda_firmware , Size , "SlaveFirmware.bin" ' ' The routine sends 64 bytes plus 2 leading bytes (Block type and ' Block number) 'Date : 5.9.2014 Dim Pointer AsWord Dim Page_write AsWord Dim Flash_byte AsByte Dim Block_nr AsByte Dim Sync AsByte Dim I2c_address_read AsByte Dim Data_block(65)AsByte
I2c_address_read = I2c_address +1 Read Irda_fw_size
Irda_fw_size = Irda_fw_size +2 Print #1 , "IRDA FW Size="; Irda_fw_size
Pointer =0
Block_nr =0 While Pointer < Irda_fw_size
Chksum =0
Sync = My_nack 'Sync not OK For Page_write =1To64'Build Packet array If Pointer <= Irda_fw_size Then Read Flash_byte
Data_block(page_write)= Flash_byte 'read FW from flash Else
Data_block(page_write)=&HFF 'pad to 64 bytes End If Incr Pointer
Next Page_write
While Sync <> My_ack 'Do until block OK I2cstart'setup i2c bus I2cwbyte I2c_address 'request slave I2cwbyte123'Block Type I2cwbyte Block_nr 'Block number For Page_write =1To64'Send 64 bytes I2cwbyte Data_block(page_write)'send byte Next Page_write
I2cstop'Release bus
Waitms5 I2cstart'setup i2c bus I2cwbyte I2c_address_read 'read slave I2crbyte Sync , Nack'Get Sync byte I2cstop'Release bus
If Sync = My_ack Then'Block OK? Print #1 , "."; Incr Block_nr 'Yes Else Print #1 , "!"; End If Waitms1'Wait abit Wend'Block OK loop Wend'Transfer finished loop
'Now send last Block all 0's I2cstart'setup i2c bus I2cwbyte I2c_address 'request slave I2cwbyte123 I2cwbyte Block_nr
For Page_write =1To64'64bytes I2cwbyte0'End CMD Next Page_write
I2cstop'Release bus
Waitms10 I2cstart'setup i2c bus I2cwbyte I2c_address_read 'read slave I2crbyte Sync , Nack'Get byte I2cstop If Sync = My_ack Then'Block OK? Print #1 , " OK" Else Print #1 , " "; Sync
End If Waitms1 EndSub
And the bootloader code is in the attachment.
Regards
Ian Dobson _________________ Walking on water and writing software to specification is easy if they're frozen.
