Programm Arduino with Bascom - step by step solution
stefan.schroeter
PostPosted: Wed Aug 13, 2014 9:06 pm    Post subject: Programm Arduino with Bascom - step by step solution Reply with quote
I am using an Arduino Uno R3 and want to programm the Arduino with Bascom. I read and tried the hints in the forum, but nothing will work for me. Finaly i used the http://wiki.mcselec.com/Getting_started_with_Arduino_UNO. This will also not work for my.
the programming windows reacts with an error window. Der Prozedureinsprungpunkt "__ctype_ptr__" wurde in der DLL "C\.... averdude.exe" nicht gefunden. that meas __ctype_ptr could not be found in the dll.
Here is my configuration:
Bascom compiler version :2.0.7.7
Bascom compiler build :2.0.7.7.004
Arduino: original Arduino R3 with an Atmega328p, 28pdip version
Windows 8.1 - Protected by the firewall from gdata 'total protection'
Bascom is running with administrator rights
I am using arduin 1.5.7
My arduino driver ist c:\windows\system32\Drivers\usber.sys
Is there a step by step solution where i can eliminate mistakes made by me?
PostPosted: Thu Aug 14, 2014 9:05 am    Post subject: Reply with quote
I assume you did not change the bootloader? So the board still works with the arduino software?
And you will see the COM port in windows device manager?
It should be possible to program with bascom using the arduino programmer option. Select Ardunino programmer, proper COM port and 19200 baud. Using F4 the board should be programmed same as with arduino.
But your first step should be to check if the driver is working and the simplest thing to do is check with arduino software.
PostPosted: Thu Aug 14, 2014 10:14 am    Post subject: Reply with quote
hello,
well you to , you lost your hair as me with arduino ?
Laughing
I'm still in W7 Windows version I hope it is ok with W8.1
In my last post I show a step by step method.
I hope your hairdresser will be satisfied !
JP Wink
stefan.schroeter
PostPosted: Thu Aug 14, 2014 12:59 pm    Post subject: Solution Reply with quote
I followed the step by step solution from JP Duval. As if by a miracle my Arduino worked fine with Bascom. Furthermore i took a saint smart uno and ... it works fine. Im happy. Thank you JP.
Thank you, albertsm, for your fast answer. The Arduino works pretty with its software. Maybe yesterday i lost the overview about baud, comport, etc.
What i realy lost is my hair like JP Duval supposed. To submit the evidence i attached a jpg file Very Happy
___________
Best regards
Stefan Schröter
PostPosted: Thu Aug 14, 2014 8:20 pm    Post subject: Reply with quote
Very Happy
