XMega PWM Question
enniom
PostPosted: Wed Aug 13, 2014 12:34 am    Post subject: XMega PWM Question Reply with quote
Hello Forum,
Using XMEGA192 and would like 2 PWM outputs on PORTD.4 and PORTD.5
The code below works for PWM-A but not for -B.
Any suggestions? I have not been able to find the method in reading the datasheet.
$regfile = "xm192a3def.dat"
$hwstack = 1200
$swstack = 1200
$framesize = 1200
$crystal = 32000000
'$noramclear
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
Config Sysclock = 32mhz                                     '--> 32MHz
Bitwait Osc_status.1 , Set                                  'Check if RC2MRDY is ready                            '
Osc_pllctrl = &B10_0_00100
Set Osc_ctrl.4                                              'Enable PLL
Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1    'use PLL
Config Portd.4 = Output
Config Portd.5 = Output
Config Tcd1 = Pwm , Prescale = 64 , Comparea = Enabled , Compareb = Enabled , Resolution = 16
Tcd1_per = &HFFFF
Tcd1_cca = 1000
Tcd1_ccb = 1000
do
loop
end
PostPosted: Wed Aug 13, 2014 8:57 am    Post subject: Reply with quote
A simulation in AVR-Studio shows no irregularities, I'd suggest to check the hardware, i.e. toggle PD5.
enniom
PostPosted: Wed Aug 13, 2014 2:57 pm    Post subject: Reply with quote
MWS,
As usual, you were correct. Thanks for taking the time to help.
