Web server - multiple access
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
bibibo
PostPosted: Mon Aug 04, 2014 6:55 pm    Post subject: Web server - multiple access Reply with quote
Hello, i made small web server but i found that multiple access at the same time is not possible. I tried launch website on two computers at the same time. Could you give me an idea how to fix it ?
PostPosted: Mon Aug 04, 2014 8:09 pm    Post subject: Reply with quote
you have only 1 socket listening. this means you can only server one client at the time.
please have a look at the provided samples which use multiple sockets.
Paulvk
PostPosted: Tue Aug 05, 2014 1:10 am    Post subject: Reply with quote
Hello bibibo
I have a new blog in the blog section with a wiznet web server it uses the 4 sockets of the W5100 with the M128 it will work ok.
It stores the TCPIP settings in eeprom and reads them from SD card or a rs232 command line and web page so they need not be hard coded but I still leave a default in the code.
I regularly use 2 PCs to work with it so I can test it with different browsers.
Regards Paul
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
