WIZ820io W5200 socketstat unexpected result
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
GrainyPCB
PostPosted: Thu Jul 24, 2014 3:43 pm    Post subject: WIZ820io W5200 socketstat unexpected result Reply with quote
Hello. Complete TCP/IP noob here, apologies in advance. I am trying to run example webserver_w5200.bas on a WIZ820io module, modified for m328. IP is pingable. Initial goal is to reach "Sock_established" and receive "GET." When I connect with a browser or Easy TCP/IP, socketstat produces a value not listed in the BASCOM-AVR help index.
For I = 0 To 7        ' for all sockets
    Tempw = Socketstat(i , 0)                                                   ' get status
    If Tempw <> 0 Then Print Tempw
    Select Case Tempw
       Case 15
            Print "what?"
       Case Sock_fin_wait
            Print "Connection being terminated"
            Socketdisconnect I
       Case Sock_established
When I connect, tempw = 15 = h0F = ????
When I disconnect, tempw = 24 = h18 = "SOCK_FIN_WAIT"
What is socketstat h0F?
On a possibly-related note, where can I find:
$include "config_MMCSD_HC-W5200.bas"
$include "Config_AVR-DOS-W5200.BAS"
Relevant portions of the example are currently block commented out.
GrainyPCB
PostPosted: Mon Jul 28, 2014 2:51 pm    Post subject: Reply with quote
Partially resolved: switched to xmega128a1 and example runs as expected. m328 SRAM limitations?
Would still appreciate if someone could help me locate:
Config_MMCSD_HC-W5200.bas
Config_AVR-DOS-W5200.bas
Thanks!
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
