ATXMEGA256A3U PORTB problem
unzeitig
PostPosted: Fri Nov 03, 2017 1:27 pm    Post subject: ATXMEGA256A3U PORTB problem Reply with quote
I have tried to transfer functional code from ATXMEGA128A3U to ATXMEGA256A3U. Simple thing for a few minutes. But I stay for a few hours because of PORTB strange behaviour - higher part of PORTB does not work (not periodically changing in code example, only 4 lower bits) in ATXMEGA256A3U as in ATXMEGA128A3U! I have simplified it to code example, there are two possibilities I have tried but it does not work. Can anybody help me?
[code]
$regfile = "xM256a3uDEF.DAT"
$hwstack = 64 '64
$swstack = 64 '64
$framesize = 64
Const Crystalfrekq = 32000000
$crystal = Crystalfrekq
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 'CPU Clock = 32MHz
Bitwait Osc_status.1 , Set 'Check if 32MHz Oscillator is ready
Bitwait Osc_status.2 , Set 'Check if internal 32.768 KHz Oscillator is ready
Osc_dfllctrl.0 = 0
Dfllrc32m_ctrl.0 = 1 'enable
Config Portb = Output
Portb = 0
Waitms 500
Portb = 255
Waitms 500
Config Vport0 = B
Ddr0 = &B1111_1111
Port0 = 0
Waitms 500
Port0 = 255
Waitms 500
[/code]
[b][color=red](BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.7.8 )[/b][/color]
PostPosted: Fri Nov 03, 2017 2:25 pm    Post subject: Reply with quote
I saw this a week ago Wink
Gues what?
Please insert this line near top of the code Wink
Disable Jtag
Hahaha, jest it should be the JTAG Wink
You can also disable it by programming the FuseBits
Have a nice day
unzeitig
PostPosted: Fri Nov 03, 2017 2:48 pm    Post subject: Reply with quote
Sure, I completely forgot it, I have used it two years ago in another project with SW JTAG control!
Thank you for your help
