Select case from too..ATinny13
PostPosted: Fri Jun 13, 2014 7:04 pm    Post subject: Select case from too..ATinny13 Reply with quote
My curiosity tells me to ask why this code does not work for ATtinny13.
I also tried to write a single line. Colon and without..
$regfile = "attiny13.dat"
$crystal = 1200000
$hwstack = 24
$swstack = 18
$framesize = 16
Dim Adc_value As Word
Config Adc = Single , Prescaler = Auto , Reference = Avcc
Config Portb.0 = Output
Led Alias Portb.0
  Waitms 10
  Adc_value = Getadc(3)
  Select Case Adc_value
   Case 1024 To 500
   Reset Led
   Case 500 To 0
   Set Led
  End Select
This is only a sample. I needed moore steps between 1024 -0
If I wrote "If Adc_value <500 and Adc_value >0 then" ..everything work.
Finally I finish this small programm another way but want to know what I do wrong.
Arera
PostPosted: Fri Jun 13, 2014 7:23 pm    Post subject: Reply with quote
Just an idea, it's not tested:
Try "case 0 to 500".
500 to 0 could be interpreted as
(Bigger than 500 AND smaller than 0), which will never be true.
PostPosted: Fri Jun 13, 2014 7:34 pm    Post subject: Reply with quote
Laughing I`m blinded... Even in help wrote from -5 to -2 so.. value can only grow Thanks
