2077 official release
Goto page 1, 2  Next
PostPosted: Fri Jan 31, 2014 11:36 pm    Post subject: 2077 official release Reply with quote
After a lot of work, and later than planned, i can announce that version 2077 is available.
You can get it using the update wiz, or you can download a full setup.
As always, you can make a backup and/or install the software in it's own folder so you can have the old and the new version.
- The help file has categories for I2C, 1WIRE, etc. which should make it more clear.
- dat files for new chips have been added.
- there is a now support for USI and Xmega slave (the i2c slave add on has been updated as well)
- there is a new/alternative i2c master soft lib
- ######################### IMPORTANT ####################################
the crc32 function has been updated. it returned the crc in the wrong byte order. Now it returns it in the right order. BUT
this means you need to change your code. I left the old code in the mcs.lib so you could copy it in and put it in a new lib to maintain code compatibility
But it is best to update your code.
- spimove() has an optional parameter. it has been discussed in this forum
- the editor has a great feature (IMO) when code explorer is active you can get info about code elements like alias, variable and constants, etc. Just press SHIFT and hover the cursor over your code to see what i mean.
- the editor can also show indent lines for structures. it can be a nice visual help. it requires the code explorer to be visible and it is best to 'proper indent' your code.
These 2 options are not 100% optimal. But i did not want to hold it back since it is already useful.
Have fun!
Madf
PostPosted: Sat Feb 01, 2014 7:38 am    Post subject: Reply with quote
Cool!!! Thank you.
Tiny
PostPosted: Sat Feb 01, 2014 9:13 am    Post subject: Reply with quote
Hi MArk,
Very nice, especially the indent for structures, Thanks
Robert_d1968
PostPosted: Sat Feb 01, 2014 12:17 pm    Post subject: Reply with quote
Thank you very much,
I'm downloading it now, it looks very nice indeed...
PeterM
PostPosted: Sat Feb 01, 2014 1:15 pm    Post subject: Reply with quote
Excellent
Peter
Plons
PostPosted: Sat Feb 01, 2014 2:52 pm    Post subject: Reply with quote
I love the indent with lines for structures, .... used to use Programmer's NotePad in case I needed overview.
Nice work Mark !
Nard
Bascom AVR ver 2.0.8.1
ProtectedParallelPortProgrammingDongle: http://www.aplomb.nl/TechStuff/PPPD/PPPD%20English.html
nicofer
PostPosted: Mon Feb 03, 2014 3:38 pm    Post subject: Reply with quote
Bascom Rocks !!
Baie goed !
Nico
nicofer
PostPosted: Thu Feb 06, 2014 2:32 pm    Post subject: Indent Reply with quote
After testing it a bit I have one function on my wishlist .
A text block select option .
Not the complete line but only the chars in a selected block , not the text to the end of a line and from beginning of the next line , this will help a lot to move selected text .
K-Edit , crimson editor , and Notepad++ has this function but can not use it with Bascom .
Please check the link http://notepad-plus-plus.org/features/column-mode-editing.html
Kind regards
Nico
PostPosted: Tue Feb 11, 2014 10:50 pm    Post subject: Reply with quote
have a look at the next update.
astroschmidt
PostPosted: Sat Feb 22, 2014 12:52 pm    Post subject: Reply with quote
The indent lines and the "code explorer" are really great enhancements.
Thanks Mark for the new functions.
What would be a great enhancement for a future versions would be tabs for each sub or label (like the tabs in Firefox).
If e.g. you want to follow a variable that is used all over the program it would ease the workflow a lot if you simply jump from tab to tab instead of scrolling through a long program.
Roger
PostPosted: Sat Feb 22, 2014 5:11 pm    Post subject: Reply with quote
but where is the version I used for my first program ? Smile
Bascom is better and better !
"Merci beaucoup" Mark for all your works
Bascom Ambassador
PostPosted: Sun Feb 23, 2014 6:08 am    Post subject: Excelent job!! Reply with quote
Mark did an excelent job.
Love this new Shift-function.
Have fun
Ben Zijlstra
PostPosted: Mon Mar 03, 2014 10:58 am    Post subject: Reply with quote
Roger
you might want to try the 'Find Refrences' function from the Code explorer. select a variable, then click right mouse and select 'Find references'. It will give a list under the variable of instances where the variable is referenced.
Neill
PostPosted: Wed Apr 09, 2014 2:03 am    Post subject: Reply with quote
Shout out to Mr Mark Alberts.
Thanks for the new features!!
Yesterday was the first time I got to use 2077 for a few hours.
I really appreciate the indent and explorer features. Certainly saves time and makes it easier to program.
BASCOM, Just gets better and better.
njepsen
PostPosted: Thu Apr 17, 2014 6:10 am    Post subject: Reply with quote
How do you get this to work?
Neil
Goto page 1, 2  Next
Page 1 of 2
