DG7GJ
Posted: Sat Jan 14, 2017 3:39 pm Post subject: Using Softcklock (RTC) together with Dcf77.lib? |
Hello!
I confused since days:
An Softclock with an 32,768kHz Crystal at Timer2 in Asyncron-Modus via "Config Clock = Soft" will rum without problems.
But if I use "Config Dcf77..." the compiler will always ignore the asynchron Timer2 always.
I dosen't matter if I configure the Timer2 with
Code: | Config Timer2 = Timer , Async = On , Prescale = 128 ', Compare = Clear
Enable Timer2 |
or manuallity with
Code: | Tccr2 = &B00000101
Ocr2 = &B00000000
Assr = &B00001000 |
After I confugure the dcf77.lib
Code: | Config Dcf77 = Pina.1 , Timer = 1 , Timer1sec = 2 , Inverted = 1 , Debug = 1 , Check = 2 , Update = 2 , Updatetime = 03 , Powerpin = Pina.0 , Powerlevel = 1 , Gosub = Sectic
The RTC will don't work anymore.
The RTC-Sectic looks like from mainklock (external 8MHz Crystal) with subotimal Prescalers.
The RTC-Seconds extremely zu long:
The RTC from the Dcf77.lib will round 54 seconds count in real 60 seconds.
An real Softklock (Timer2 asynchron with 32,768kHz Crystal at TOSC-Pins) will only differ araund +-1seconds over 24 Hours.
The only thing that i Try since many days:
An free running RTC with 32,768kHz Crystal at asynchron Timer2, wich will synchonisize once per Day with the DCF77-Rountine.
How it is possible?
Juergen[/quote]
Posted: Sat Jan 14, 2017 3:50 pm Post subject: |
first of all try the sample, dcf77 you will find it under datetime sample
then try to add a timer
JP |
Posted: Sat Jan 14, 2017 4:21 pm Post subject: |
If you are using dcf77 then there is already a softclock running so I don't think you can run 2 clocks at the same time. _________________ www.evertdekker.com Bascom code vault |
Posted: Sat Jan 14, 2017 5:24 pm Post subject: |
Whoooo Evert
2000 post !
Bravo !
JP |
Posted: Sat Jan 14, 2017 5:38 pm Post subject: |
Missed that !
2000 posts in 12 year, that's a lot of hours typing.
What I find even more incredible is my an#148, that has been downloaded now 158000 times.
Thanks JP
Now 2001 posts, time for some champagne. _________________ www.evertdekker.com Bascom code vault |
Posted: Sat Jan 14, 2017 9:20 pm Post subject: |
Well done Evert ! _________________ Mark |
mat-sche
Posted: Wed Oct 11, 2017 8:29 am Post subject: |
Evert wrote: | If you are using dcf77 then there is already a softclock running so I don't think you can run 2 clocks at the same time. |
soooo...... I have the same problem with the dcf77 routine. From time to time my dcf77 receive signal is very bad and I can't update my softclock over the routine. I use the atmega2560 with a quarz on tosc 1/2. It's possible to use it with the dcf77 routine?
thank's and gruesse aus Deutschland |
Posted: Wed Oct 11, 2017 9:41 am Post subject: |
the problem is : DCF77 routine used by bascom use or not the soft clock var from Bascom (_sec _min,.... _year) ? yes it does ! I checked.
Because bad reception on DCF77 I don't use it any more, now I use DS3231 RTC, it is very accurate.
And, I think you can use it with DCF77 if you need a better accuracy.
I give you the .inc file, if you want to use it you need to replace the Bascom clock var (_sec _min,.... _year) with your own variables
You can found some shield with DS3231 for less than a good crystal. because some 32...k crystal are very bad, I tested some with a frequency meter
add in you main prog
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
' Configure the SCL and SDA pins
Config Sda = Portd.1
Config Scl = Portd.0
'--------------constant--------------------------------------------------------------------------
Const Ds3231r = &B11010001 'Ds3231 is very similar to DS1307 but it include a precise crystal
Const Ds3231w = &B11010000
and put the GND of M3260 common with DS3231...
JP |
mat-sche
Posted: Wed Oct 11, 2017 11:31 am Post subject: |
Hello JP
Thank's for your replay!
Currently I use the ds 1307 RTC-Chip from Dallas.
My Think it was, the best way is I use a softclock with a µC and a high precission quarz on the tosc 1/2 pin from controller and use the dcf signal to update from time to time the internal clock data.
Now I'm looking for a method to change the dcf lib. It's possible this? |
Posted: Wed Oct 11, 2017 5:31 pm Post subject: |
I make a mistake, I reed to fast the .lib file, the var are different but the lib use the
Getdatetime:
Setdate:
Settime:
where these var are called. please read the config clock chapter in the help about these label, my inc file is done with these help file.
I don't know enough assembler and the lib to help you more.
so If you modified the lib, you have to make a copy before !
Let me know for the future.
"bon courage"
JP |
Posted: Wed Oct 11, 2017 7:14 pm Post subject: |
i think this has been asked before and if i remember there is even code for it, but i am not sure.
when using dcf77 there are multiple variables created.
the most important ones :
Dcf_sec As Byte
Dcf_min As Byte
Dcf_hour As Byte
Dcf_day As Byte
Dcf_month As Byte
Dcf_year As Byte
Dcf_weekday As Byte
you can check those and/or fill them. for other dcf variables, check the report. _________________ Mark |
