Making DNS & NTP requests
PostPosted: Mon May 23, 2016 11:54 am    Post subject: Making DNS & NTP requests Reply with quote
Instead of putting this in the web server blog
I thought I would put it separately so it can be fully explained
Both Ben and SIX1 have made code to do this
Ben for the ENC28J60
SIX1 for wiznet
But they did not break it down to a byte by byte explanation
and with some work so far I find I can use less memory to do it
I also will try to make it more portable
We need to make a DNS request to get an IP "A" record from the time server pool
then when we have that we can then ask for the time NTP request
First a break down of a DNS request for www.mcselec.com
'  DNS request for www.mcselec.com
'                               w  w  w      m  c  s  e  l  e  c     c  o   m
'  X Y 1 0 0 1 0 0 0 0 0 0 [3] 77 77 77 [7] 6D 63 73 65 6C 65 63 [3] 63 6F 6D [0] 01 01
'                          [3] for 3 characters   [7] for 7 characters   [3] for 3 characters  [0] for no characters
'                                   these will change depending on how many characters in the URL name
'    X & Y are random numbers to identify the message
'     last two 01 01   IP "A" record
'                   0F 01  MX record
' So the  bytes are
  '16 bit random number ,bytes 1 & 2
  'byte 3 &H01
  'byte 4 &H00
  'byte 5 &H00
  'byte 6 &H01
  'byte 7 &H00
  'byte 8 &H00
  'byte 9 &H00
  'byte 10 &H00
  'byte 11 &H00
  'byte 12 &H00
  'byte 13 &H03   3 characters
  'byte 14 &H77   w
  'byte 15 &H77   w
  'byte 16 &H77   w
  'byte 17 &H07    7 characters
  'byte 18 &H6D   m
  'byte 19 &H63   c
  'byte 20 &H73   s
  'byte 21 &H65   e
  'byte 22 &H6C   l
  'byte 23 &H65   e
  'byte 24 &H63   c
  'byte 25 &H03   3 characters
  'byte 26 &H63   c
  'byte 27 &H6F   o
  'byte 28 &H6D  m
  'byte 29 &H00   0 characters
  'byte 30 &H01   "A"  record
  'byte 31 &H01    for Internet
Regards Paul
Bascom Ambassador
PostPosted: Mon May 23, 2016 3:35 pm    Post subject: Nice work Reply with quote
Thanks for sharing Paul!
PostPosted: Tue May 24, 2016 10:45 am    Post subject: Reply with quote
Now a program that builds the request
then prints it to a terminal in HEX to compare it to the example
I used an Arduino M2560
Note 1194 bytes of flash without the print to terminal
Next step is to put it into a function just wish we had local arrays!
Regards Paul
$regfile = "m2560def.dat"
$baud = 19200
$hwstack = 100
$swstack = 100
$framesize = 100
Dim Buffer(200) As Byte
Dim Pos As Byte
Dim Url As String * 40
Dim Work(15) As String * 20
Dim Char As String * 1
Dim Lenurl As Byte
Dim W As Byte
Dim X As Byte
Dim Y As Byte
Dim Z As Byte
  Url = "www.mcselec.com"                                   'use example url
'  X Y 0 1 0 1 0 0 0 0 0 0 [3] 77 77 77 [7] 6D 63 73 65 6C 65 63 [3] 63 6F 6D [0] 01 01
'53360100000100000000000003777777076D6373656C656303636F6D000101
'                   0F 01  MX record
' So the  bytes are
  'byte 3 &H01
  'byte 4 &H00
  'byte 5 &H00
  'byte 6 &H01
  'byte 7 &H00
  'byte 8 &H00
  'byte 9 &H00
  'byte 10 &H00
  'byte 11 &H00
  'byte 12 &H00
  'byte 14 &H77   w
  'byte 15 &H77   w
  'byte 16 &H77   w
  'byte 18 &H6D   m
  'byte 19 &H63   c
  'byte 20 &H73   s
  'byte 21 &H65   e
  'byte 22 &H6C   l
  'byte 23 &H65   e
  'byte 24 &H63   c
  'byte 26 &H63   c
  'byte 27 &H6F   o
  'byte 28 &H6D  m
'Clear buffer
For Pos = 1 To 200
         Buffer(pos) = &H00
 'First two bytes are a random 16 bit number
 'this is the transaction ID
     Buffer(1) = Rnd(&Hff)
     Buffer(2) = Rnd(&Hff)
'Now to set the  flags bytes 3 & 4 Standard query = &H1000
     Buffer(3) = &H01
'Now the Questions bytes 5 & 6 = &H0001
     Buffer(6) = &H01
     Pos = 13                                               'point to byte 13 in the buffer
  'Split up the parts of the URL  www    mcselec    com
Lenurl = Split(url , Work(1) , ".")
  'Lenurl will = 3 so we have 3 parts to this URL
  'work(1)  will be   www
  'work(2) will be    mcselec
  'work(3) will be    com
  'now we need to go through each part
  'and build up the ASCII packet
  For X = 1 To Lenurl
     Z = Len(work(x))
      Buffer(pos) = Z                                       'find the number of characters in the part of the URL
      Incr Pos                                              'move to the next byte in the buffer
     For W = 1 To Z
       Char = Mid(work(x) , W , 1)
       Buffer(pos) = Asc(char)
       Incr Pos
    Buffer(pos) = &H00                                      'no more url's
    Incr Pos
    Buffer(pos) = &H01
    Incr Pos
    Buffer(pos) = &H01
   For X = 1 To Pos
   Print Hex(buffer(x))
PostPosted: Thu May 26, 2016 9:50 am    Post subject: Reply with quote
Now moving it into a function
still some more work to be done but it works
$baud = 19200
$hwstack = 100
$swstack = 100
$framesize = 100
Dim Work(5) As String * 20
Dim Result As String * 40
Dim Urls As String * 40
Declare Function Dns_req(byref Url As String * 40 ) As String * 40
 ' Url = "www.mcselec.com"                                   'use example url
'                   0F 01  MX record
' So the  bytes are
  'byte 3 &H01
  'byte 4 &H00
  'byte 5 &H00
  'byte 6 &H01
  'byte 7 &H00
  'byte 8 &H00
  'byte 9 &H00
  'byte 10 &H00
  'byte 11 &H00
  'byte 12 &H00
  'byte 14 &H77   w
  'byte 15 &H77   w
  'byte 16 &H77   w
  'byte 18 &H6D   m
  'byte 19 &H63   c
  'byte 20 &H73   s
  'byte 21 &H65   e
  'byte 22 &H6C   l
  'byte 23 &H65   e
  'byte 24 &H63   c
  'byte 26 &H63   c
  'byte 27 &H6F   o
  'byte 28 &H6D  m
Urls = "www.mcselec.com"
Result = Dns_req(urls)
'print buffer to terminal in HEX format
'to confirm result
   For X = 1 To Pos
Function Dns_req(byref Url As String * 40) As String * 40
Local Pos As Byte
Local Char As String * 1
Local Lenurl As Byte
Local W As Byte
Local X As Byte
Local Y As Byte
Local Z As Byte
' Print Urls ; "   url"
'Clear buffer
For Pos = 1 To 200
         Buffer(pos) = &H00
     Buffer(3) = &H01
     Buffer(6) = &H01
  For X = 1 To Lenurl
     Z = Len(work(x))
     For W = 1 To Z
       Incr Pos
    Incr Pos
    Buffer(pos) = &H01
    Incr Pos
    Buffer(pos) = &H01
  End Function
Bascom Ambassador
PostPosted: Mon Aug 08, 2016 5:24 pm    Post subject: NTP? Reply with quote
Paul
Any luck on the NTP?
Have fun
Ben Zijlstra
six1
PostPosted: Tue Aug 09, 2016 6:29 am    Post subject: Reply with quote
Hi Paul,
i've done this "byte by byte" Very Happy
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=11141&highlight=dns
PostPosted: Tue Aug 09, 2016 7:55 am    Post subject: Reply with quote
Hello Ben , six1
Been busy with other things have not tested my DNS yet against a server
So I am yet to get on to the NTP
Regards Paul
