How can i write a bigger string ? I have the string with more than 255 characters and i have a problem with displaying in the web browser
If S ="<select name={034}IN1INACT{034} size={034}1{034}>"Then If Input1_output2_status =0Then
S = S +"<option Selected>--</option>" Else
S = S +"<option>--</option>" End If
If Input1_output2_status =1Then
S = S +"<option Selected>ON-Vystup 1</option>" Else
S = S +"<option>ON-Vystup 1</option>" End If
If Input1_output2_status =2Then
S = S +"<option Selected>OFF-Vystup 1</option>" Else
S = S +"<option>OFF-Vystup 1</option>" End If
If Input1_output2_status =3Then
S = S +"<option Selected>ON-Vystup 2</option>" Else
S = S +"<option>ON-Vystup 2</option>" End If
If Input1_output2_status =4Then
S = S +"<option Selected>OFF-Vystup 2</option>" Else
S = S +"<option>OFF-Vystup 2</option>" End If
If Input1_output2_status =5Then
S = S +"<option Selected>ON-Vystup 3</option>" Else
S = S +"<option>ON-Vystup 3</option>" End If
If Input1_output2_status =6Then
S = S +"<option Selected>OFF-Vystup 3</option>" Else
S = S +"<option>OFF-Vystup 3</option>" End If
If Input1_output2_status =7Then
S = S +"<option Selected>ON-Vystup 4</option>" Else
S = S +"<option>ON-Vystup 4</option>" End If
If Input1_output2_status =8Then
S = S +"<option Selected>OFF-Vystup 4</option>" Else
S = S +"<option>OFF-Vystup 4</option>" End If
If Input1_output2_status =9Then
S = S +"<option Selected>Restart</option></select>" Else
S = S +"<option>Restart</option></select>" End If End If
do you use $bigstrings ? that would be required. or specify the lib with $lib "bigstrings.lbx"
you also need a special version of the lib that will send a big string. you can contact support for that.
a simpler alternative :
- send the string in pieces. _________________ Mark
