tioaditia
Posted: Fri Apr 04, 2014 10:44 pm Post subject: (ASK) PICBASIC to BASCOM |
SOURCE CODE of how to BASCOM AVR PICBASIC
using ATmega8 to control IC IC TSA5511.
Please help.
Code: |
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTD
DEFINE LCD_RSBIT 1
DEFINE LCD_EREG PORTD
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
DEFINE I2C_SCLOUT 1 'Set serial clock to bipolar instead of open-collector
' definition I2C communication
SCL var PORTB.1 ' SCL on RB1
SDA var PORTB.0 ' SDA on RB0
'press:
MEMO var PORTB.3 '
UP var PORTB.4 ' press for FREQ UP RB.4
DOWN var PORTB.5 ' press for FREQ DOWN RB.5
INPUT UP 'Up et Down sont des entrées
INPUT DOWN
INPUT MEMO
'Fmin =88 MHz, F max= 108 MHz
' ** DECLARATION OF THE VARIABLES
b1 var BYTE
b2 var BYTE
b3 var BYTE
b5 var BYTE
F1 var WORD
F2 var WORD
F3 var WORD
ADDR1 VAR BYTE
TMP VAR WORD
TMP_LO VAR TMP.LOWBYTE
TMP_HI VAR TMP.HIGHBYTE
PLLBASE VAR WORD
PLL VAR WORD
LO VAR PLL.LOWBYTE
HI VAR PLL.HIGHBYTE
PAS VAR BYTE '1=125kHz, 2=250kHz, 4=500kHz, 8=1MHz
'*** INITIAL DATA ***
ADDR1=$C2 'adress I2C of SDA5055 (ADDR1=$C0 , adress I2C of TSA5511)
PLLBASE=696 'beginning with 87 MHz : 87 / 0,125 = 696
PAS = 1 'step of 0.125 MHZ by default ?????
PAUSE 100
LCDOUT $FE, 1 ' Clear LCD screen
LCDOUT " PLL FM 88-108" ' post text during 1 second
LCDOUT $FE,$C0
LCDOUT " BT-20"
PAUSE 1000
EEPROM 0,[$90,$01] 'initial data TMP = PLLBASE corresponds to F = 88 MHz
'The starting point is 88 MHz given by PLLBASE. One adds a shift of 125kHz * TMP
'TMP is on 16 bits, therefore 65535 possible frequencies.
'*** READING OF THE DECALAGE TMP ***
READ 0,TMP_LO 'reads the 8 bits of weak weight
READ 1,TMP_HI 'reads the 8 bits of strong weight
' *** BEGINNING OF THE PROGRAM***
MAIN:
PLL = PLLBASE + TMP
I2CWRITE SDA,SCL,ADDR1,[HI,LO,$8E] 'Sending of the data to the module
GOSUB CALCUL 'calculate the frequency for posting
GOSUB AFFICHAGE 'post the frequency
PAUSE 500
'*** press routine ***
BOUCLE:
BUTTON UP,0,10,2,b1,1,MONTE 'supervise the button UP
BUTTON DOWN,0,10,2,b2,1,DESCEND 'supervise the button DOWN
BUTTON MEMO,0,255,0,b5,1,STORE 'supervise the button MEMO
' only step size of 125KHz is handled
' BUTTON CH_PAS,1,255,0,b3,1, CHOIX 'supervise the button PAS
PAUSE 100 'pauses of 0.1s
GOTO BOUCLE
MONTE: '** INCREASE THE FREQUENCY OF 1 PAS (STEP)
TMP = TMP + PAS
IF TMP > 168 THEN TMP = 0 'Fmax = 108 MHz ---> (Fmax - Fmin) / 0,125 -> (108-87)/0,125 = 168
GOTO MAIN
DESCEND: '** DECREASE THE FREQUENCY OF 1 PAS (STEP)
IF TMP = 0 THEN TOP
TMP = TMP - PAS
GOTO MAIN
TOP: TMP=168 ' max reading in Tmp
GOTO MAIN
GOTO BOUCLE
GOTO BOUCLE
CALCUL: ' ** CALCULATION OF THE FREQUENCY
F1 = PLL 'cut off 1GHz
F2 = F1/8 'give them MHz
F3 = 125*(F1//8)
RETURN
AFFICHAGE:
LCDOUT $FE, 1 'Clear LCD screen
LCDOUT #F2 'post the other digits
LCDOUT "." 'post the comma
LCDOUT #F3 'post the Khz
LCDOUT " MHz "
STORE:
WRITE 0, TMP_LO
WRITE 1, TMP_H |
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.7 ) |
kimmi
Posted: Sat Apr 05, 2014 8:27 am Post subject: |
I did some project for U6205B for ham radio pll some time ago
here is the code I used change for TSA5511 100Khz steps (PLL XTAL 6.4Mhz)
missing info about what Xtal the TSA5511 use 4 mhz or 6.4Mhz ?
with PLL Xtal 6.4 Mhz you get 100Khz steps
4 Mhz is odd 125Khz steps for FM radio
'Test code
Code: | 'TSA5511 Test code NOTE !!!! pll xtal 6.4 MHz give 100 Khz steps
' http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12237&sid=3d032597060ec1e872c3a17eb0287041
'$sim
$regfile = "m8def.DAT"
$crystal = 8000000
$hwstack = 32
$swstack = 24
$framesize = 32
Config Portb.4 = Input 'KEY UP 100 kHz
Config Portb.5 = Input 'KEY DOWN 100 kHz '
Portb.4 = 1 'UP set high on keypress we go low
Portb.5 = 1 'DOWN set high on keypress we go low
'LCD setup
Config Lcdpin = Pin , Db4 = Portd.0 , Db5 = Portd.1 , Db6 = Portd.2 , Db7 = Portd.3 , E = Portd.4 , Rs = Portd.5
Config Lcd = 16 * 2
Cursor Off
Config Scl = Portb.1 'serial clock SCL pin 1
Config Sda = Portb.0 'serial data SDA pin 0
Declare Sub Update
Dim Snd_bytes As Byte
Dim Ax (4)as Byte
Dim Pll As Word
Dim Pll_lsb As Byte
Dim Pll_msb As Byte
Dim Lcd_frq As Single
Dim Pll_lock As Byte
Const Address_write = 194 'address
Const Charge_pump = 142 ' 0.100 pr step 6.4 MHz
Const Control_bit = 10 'port
Pll = 870 '87/0.100
Cls
Locate 1 , 1
Lcd "PLL FM 87-108"
Locate 2 , 5
Lcd "BT-20"
Wait 2
Call Update
'step 100 Khz UP
If Pinb.4 = 0 Then
Pll = Pll + 1
Call Update
Loop Until Pinb.4 = 1
Bitwait Pinb.4 , Set 'wait until key relase
'step 100 Khz DOWN
If Pinb.5 = 0 Then
Pll = Pll - 1
Call Update
Loop Until Pinb.5 = 1
Bitwait Pinb.5 , Set 'wait until key relase
Sub Update ()
If Pll > 1080 Then Pll = 870 ' 108 Mhz
If Pll < 870 Then Pll = 1080 ' 87 MHz
Pll_msb = High(pll )
Pll_lsb = Low(pll )
Ax (1) = Pll_msb
Ax (2) = Pll_lsb
Ax (3) = Charge_pump
Ax (4) = Control_bit
Snd_bytes = 4
I2csend Address_write , Ax (1) , Snd_bytes
Cls
Locate 1 , 1
Lcd_frq = Pll * 0.100
Lcd Fusing(lcd_frq , "000.000") ; " Mhz"
Waitms 180
End Sub
End |
_________________ / Kim |
tioaditia
Posted: Sat Apr 05, 2014 8:17 pm Post subject: |
Ok thanks Mr.Kimmi
sorry there is some source code that I do not understand.
1.How step how to determine the outcome of its datasheet, I do not really understand??
2. This code is generated from the sum of the numbers where?
Code: | Const Address_write = 194 'address
kimmi
Posted: Sat Apr 05, 2014 8:22 pm Post subject: |
Quote: | Const Address_write = 194 |
same as 5511 I2C address &HC2
pll xtal calculation :
6.4Mhz = 6400/512 = 12.5khz * 8 = 100Khz steps
freq :
99.4 mhz = 994 * 0.1 =99.4 Mhz _________________ / Kim |
tioaditia
Posted: Sat Apr 05, 2014 9:10 pm Post subject: |
Ok .. I just try to source code.
thanks for coming down. |
kimmi
Posted: Sat Apr 05, 2014 10:19 pm Post subject: |
Here is a test code for both 4 & 6.4 Mhz
Setup PLL xtal see code
'SELECT THE PLL XTAL FREQ Pll_xtal = 0 ' 6.4Mhz / 1 = 4Mhz
Pll_xtal = 1
Code: | 'TSA5511 Test code NOTE !!!! pll xtal 6.4 MHz 100 Khz steps 4Mhz 125 Khz steps
'$sim
$crystal = 8000000
$hwstack = 32
$swstack = 24
$framesize = 32
Config Portb.4 = Input 'KEY UP kHz
Config Portb.5 = Input 'KEY DOWN kHz '
'LCD setup
Config Lcd = 16 * 2
Cursor Off
Declare Sub Update
Dim Ax (4)as Byte
Dim Pll As Word
Dim Pll_lsb As Byte
Dim Pll_msb As Byte
Dim Pll_xtal As Byte
'SELECT THE PLL XTAL FREQ 0 = 6.4Mhz / 1 = 4Mhz
Pll_xtal = 1 '6.4Mhz
If Pll_xtal = 0 Then
Pll = 870 '87/0.1 6.4 MHZ
Else
Pll = 696 '87 / 1.25 4 mHZ
Cls
Locate 1 , 1
Lcd "PLL FM 87-108"
Locate 2 , 5
Lcd "BT-20"
Wait 2
Call Update
'step 1 Khz UP
If Pinb.4 = 0 Then
Pll = Pll + 1
Call Update
'step 1 Khz DOWN
If Pinb.5 = 0 Then
Pll = Pll - 1
Call Update
Sub Update ()
''6.4 Mhz
Else
'4 Mhz
If Pll > 864 Then Pll = 696 ' >108 Mhz set 87Mhz
If Pll < 696 Then Pll = 864 ' < 87 MHz set 108 Mhz
Pll_lsb = Low(pll )
Ax (1) = Pll_msb
Ax (2) = Pll_lsb
Snd_bytes = 4
Cls
Locate 1 , 1
Lcd_frq = Pll * 0.100 '6.4 Mhz
Else
Lcd_frq = Pll * 0.125 ' 4 Mhz
Waitms 180
End Sub
End |
dekorresley
Posted: Sun Apr 06, 2014 7:59 pm Post subject: |
whether this program could be for the control IC LC72131??
Please its support Mr.
how about to controler IC LC72131?? |
kimmi
Posted: Sun Apr 06, 2014 8:17 pm Post subject: |
no this works for 5511 the LC72131 is not supported by I2c its SPI
I have not used the LC72131 so can't help you with this chip _________________ / Kim |
