$regfile="8515def.dat"' specify the used micro $crystal=4000000' used crystal frequency $baud=19200' use baud rate $hwstack=32' default use 32 for the hardware stack $swstack=10' default use 10 for the SW stack $framesize=40' default use 40 for the frame space
'to set the PWM registers, just assign a value to the compare A and B registers Compare1a=100 Compare1b=200
'Or for better reading : Pwm1a=100 Pwm1b=200 End
I have connected my two motors to first and second ports. By using Pwm1a and Pwm1b I am able to control the speed of those two motors. How do I control the speed of the third motor ? Please help.
