Posted: Fri Feb 14, 2014 2:37 pm Post subject: avr dos problem?
I have write a program that use sdhc card so I use config_mmcsd_hc.bas and mmcsd_hc.lib.
All work fine but if I set (in config_mmcsd_hc.bas) spsr.spix2=1 program doesn't work.
If the capacity of SDHC is more then 2GB Diskfree() function return the value
after 20sec and the access to the SDHC for create folder and file is about the same (20 sec.)
I have tested SDHC 4GB class 4 and class 6.
SPI with the double speed with SDHC not work but work with SD.
I'm using ATmega2561 @16MHz and bascom 2.0.7.7
Can some one help me?
[b][color=red](BASCOM-AVR version : 2.0.7.7 )[/b][/color]
