Fast library for SSD1289 LCD + Proteus Model
Goto page Previous  1, 2, 3
hobby
PostPosted: Wed Jul 24, 2019 12:48 am    Post subject: Reply with quote
Hello,
Many thanks for library.
Just little feedback:
I have tested the saintsmart shield with the demo of arduino code, works.
I have tested (only display), the code @ Nov 06, 2016 12:21 am, works.
I have create new shield using the same schematic of saintsmart*, i have just added FET for backlight.
I test my new shield with arduino demo code, works.
I test with code @ Nov 06, 2016 12:21 am, not works !!!!
I have modified the library with the code from last post mkcreta, it's works.
Thanks
Olivier
* Stupid shield, not possible to get orther port....
DL2EBV
PostPosted: Wed Aug 23, 2023 5:17 pm    Post subject: SSD1963 Display 480x272 Init-Data Reply with quote
Hello,
just trying to program a SSD1963-display with resolution 480x272 with a shield for a Arduino-mega2560 board using BASCOM and the 2014-version of the library.
Just shows nothing on the display.
Does anybody have the init-sequence with all the values for PLL and Synch for the resolution?
Would help I think...
Greetings, Ernst
enniom
PostPosted: Mon Aug 28, 2023 7:36 pm    Post subject: Reply with quote
Hello Ernst,
This is successful for the PLL
   Res_disp = 0 : Waitms 10 : Res_disp = 1 : Waitms 10      'Reset Display
   Call Ssd1963_select_reg(&He2)                            'PLL multiplier
        Call Ssd1963_write_data(24)                         'M = 24
        Call Ssd1963_write_data(&B001_01011)                'N = 11
        Call Ssd1963_write_data(&B00000_1_00)               'Execute setting PLL    final setting is 250/12 = 20.83 MHz
                                                            'This seems to be the lowest PLL without flickering
        Call Ssd1963_write_data(&H54)                       '54 = dummy
   Call Ssd1963_select_reg(&He0)                            'E0
        Call Ssd1963_write_data(&H01)                       'start PLL
        Waitus 200
        Call Ssd1963_write_data(&H03)                       'LOCK PLL
   Call Ssd1963_select_reg(&H01)                            'Software reset
   Waitms 100
Regarding the "Synch", let me know which register you need and I will post it.
E
Page 3 of 3
