NOKIA-N73 LCD Library
Goto page 1, 2, 3  Next
Mrshilov
Bascom LCD Guru
PostPosted: Wed Jan 29, 2014 12:32 pm    Post subject: NOKIA-N73 LCD Library Reply with quote
Library for NOKIA LCD models:
3720c, 5320, 5330, 5610, 5630, 5700, 5730, 6110n, 6120с, 6208, 6220с, 6300, 6303, 6303i, 6350, 6500, 6500s, 6555, 6600, 6600s, 6720, 6730, 6760, 7500, 8600,Е52, Е55,Е65, Е66, Е75, N71, N73, N75, N76,N77, N78, N79, N81, N82, N93 and others with controller MC2PA8201 from "MagnaChip". Resolution is 240x320.
Library works in Submode = New, so its very easy to include in project and unused Subs are not compiled to save memory space.
Also to save space you may use reduced Fonts, like Font36x56 in example. It has only digits, placed at position 33...42. To correct this shift simply use Digit_font = 1.
Any Fons may be included via $include. Supports both types of BASCOM Fonts - "Color" and "B&W".
You can display 8-bit (BGC) and 16 bit (BIN) pictures. Also 16 bit pictures can be loaded from SPI-Flash ROM. To prepare bin-file from bmp, gif, jpg, wmf, emf, ico I wrote special program Pic2Bin.
Library is fast. I specially write it to work quickly. In this video test program working at 8MHz.
http://www.youtube.com/watch?v=gmRyjNDrdFM&feature=youtu.be
PostPosted: Wed Jan 29, 2014 12:47 pm    Post subject: Reply with quote
Hello Mrshilov,
Thank you for publishing this great piece of work. I see that everything one need is included in the files.
The demo is great. I liked the funny pictures, especially the one with the car crash.
It is great to see the shared code contributions.
Tubeampman
PostPosted: Wed Jan 29, 2014 5:13 pm    Post subject: Reply with quote
Hi
Nice work, thanx for sharing.
Did you use a levelconverter, series resistors or is the lcd input 3/5volt tolerant.
Øyvind
Mrshilov
Bascom LCD Guru
PostPosted: Thu Jan 30, 2014 6:02 am    Post subject: Reply with quote
As we see in datasheet, maximum Logic level is 1.95V, for LCD drive is 2.95V. No official tolerance to 3/5V.
For my experiment I use resistor dividers, but my friends tried 3.3V for both levels and LCDs works good. No blue smoke.
Tubeampman
PostPosted: Thu Jan 30, 2014 11:26 pm    Post subject: Reply with quote
Hi
Thanx for the answer, yep i saw it in the schematic, but would just ask to be shure.
I am going to use a dedicated avr on 1,8v for the LCD.
Thanx
doncarlos
PostPosted: Sun Feb 23, 2014 4:59 pm    Post subject: Reply with quote
Mrshilov!
Thanks for sharing the project! Can you provide some PCB drawing or photos of the adapter board? I would like to use this with my xmega128.
View user's profile MSN Messenger
Mrshilov
Bascom LCD Guru
PostPosted: Sun Feb 23, 2014 5:30 pm    Post subject: Reply with quote
PCB in Cadsoft Eagle format. Pin compatible with ILI9325-8-bit LCD.
doncarlos
PostPosted: Sun Feb 23, 2014 6:16 pm    Post subject: Reply with quote
Thanks!! Somehow I will try to make this PCB. This would be my first board which uses SMD components.
Arek2014
PostPosted: Tue Mar 03, 2015 6:36 pm    Post subject: Reply with quote
Hello, very good job.
I have problems... when i use atmega32 (dip40 or tqfp44), supply 5V, and lcd nokia divider 1k/2k , supply 3,3V its ok !!!
but when i use atmega128 tqfp, 5V supply, and nokia with same divider , supply - lcd not working.
lcd crash... only works lcd_clear "color"
why ?
i must use translator ? for comunication atmega with lcd ?
pozdr. Arek
Mrshilov
Bascom LCD Guru
PostPosted: Tue Mar 03, 2015 9:38 pm    Post subject: Reply with quote
If used port F you need to disable JTAG
MCUCSR.7=1
MCUCSR.7=1
Arek2014
PostPosted: Wed Mar 04, 2015 6:03 am    Post subject: Reply with quote
Yes jtag is off, atmega103 compability off. Data portB, stering pd.0, pd.1, pd.2
Mrshilov
Bascom LCD Guru
PostPosted: Wed Mar 04, 2015 1:05 pm    Post subject: Reply with quote
On PortB exist hardware SPI, is it turned OFF?
Arek2014
PostPosted: Wed Mar 04, 2015 2:11 pm    Post subject: Reply with quote
I use to programming usbasp. Pdo,pdi, sck, reset, its ok? How to change?
Mrshilov
Bascom LCD Guru
PostPosted: Wed Mar 04, 2015 4:51 pm    Post subject: Reply with quote
I'm talking about this strings:
' For load Pictures from SPI-ROM you must configure SPI:
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
Spsr.0 = 1 : Spcr.0 = 0 : Spcr.1 = 0                        'F_spi = F_osc / 2
Ss_spi_rom Alias Portb.6 : Config Ss_spi_rom = Output : Ss_spi_rom = 1       'Chip Select pin
Spiinit
They must be commented if you use PORTB for data.
Arek2014
PostPosted: Wed Mar 04, 2015 4:58 pm    Post subject: Reply with quote
i don't use spi, sdcard,
when data port was portE there was the same problem.
Page 1 of 3
