njepsen
Posted: Thu Jan 09, 2014 6:49 am Post subject: CRLF inside file |
I have been banging my head against this for several hours. I have a subroutine that writes an error file to an SD card every 15 minutes. The error_msg gets built up event by event during the previous 15 minutes. The code looks like this, and works fine.
Code: |
'generates the error_message
error_msg = error_msg + "read error at ";datetimestr
Code: |
Write_to_errorlog:
'Appends current error message to SD card file and creates file if file not exist.
gosub sd_error_check
Disable Interrupts
Chdir "\" 'to root
Mkdir "Errorlog" 'mk dir if not exist
Chdir "\"
Chdir "Errorlog"
Myfilename = "error___.txt"
Open Myfilename For Binary As #128
Filelength = Lof(#128)
Filelength = Filelength + 1 'find where to append
Seek #128 , Filelength 'set pointer
Tempb = Len(error_msg)
Put #128 , Error_msg , , Tempb
Cr = 13 : Lf = 10
Put #128 , Cr , , 1 'CRLF between records
Put #128 , Lf , , 1
Flush #128
Close #128
Print #1 , ">> Entry saved to errorlog " 'debug port
Print #1 , ""
Chdir "\" 'back to root dir
Error_msg = ""
If my error_msg is a quite long such as " the quick brown fox jumps over the fat and lazy dog. there is a temperature error. there is a time error',
then the log file is seen over several lines with notepad and looks clumsy, so i want to embed a crlf in the text as i build the error file in code.
Like this:
Code: |
error_msg = error_msg + "read error at ";datetimestr + chr(10)+ chr(13)
This would mean that each error event would be viewed on a separate line.
But - that doesn't work, and nor have any of the other variations I have tried, and I have run out of ideas.
Incidently this line in my write file routine does work
Code: |
Put #128 , Lf , , 1 |
and every new write to the SD card is separated by a CRLF, but I cant seem to be able to add additional CRLF embedded in my error string, as it gets built up. _________________ Neil |
Posted: Thu Jan 09, 2014 10:14 am Post subject: |
for windows you must use chr(13)+ chr(10) , not chr(10)+ chr(13) _________________ Mark |
njepsen
Posted: Thu Jan 09, 2014 10:54 am Post subject: |
the order matters? _________________ Neil |
Posted: Thu Jan 09, 2014 2:39 pm Post subject: |
to notepad and most windows editors it does. Just create a text file and look with a binary viewer or editor or just test it. _________________ Mark |
njepsen
Posted: Fri Jan 10, 2014 12:39 am Post subject: |
Thankyou Mark. That was indeed the problem. I never thought to try them in the other (correct) order. _________________ Neil |
