kiki
Posted: Sun Jan 05, 2014 8:16 am Post subject: problem with aritmatic |
hi all..i need your help..
Waktu:
Start Timer1
Set Portb.4 'this pin use for active dinamo
Pul = Pul + 6 ''here the problem..if interrupt we switch 2 time then "pul" is 12 so i want 6+6=2,how to create that
If Pul > 9 Then 'one time i switch the interrupt "pul"=6 and "det"=0 and timer is 60 inthe same time
Pul = 0 'two time i switch the interrupt,"rat"=1 and "pul"=2 and "det"=0 and timer is 120 inthe same time
Rat = Rat + 1 'example:timer is countdown until "pul"=2 and "det"=5 so if we switch the interrupt then "pul" and "det"
must be add 60 so"pul"=8 and "det"=5
$regfile = "attiny2313.dat"
$crystal = 4000000
$sim
Dim A As Byte
Dim Det As Byte
Dim Pul As Byte
Dim Rat As Byte
Config Pind.4 = Input
Config Portd.1 = Output
Config Portb = Output
Config Timer1 = Timer , Prescale = 8
Config Int1 = Low Level
Enable Timer1
Enable Int1 ,
On Int1 Waktu
On Ovf1 Nilai
Stop Timer1
Tcnt1 = 65386
Portb = Lookup(det , Seg) 'for 7 segment
Waitus 1
Portd = &B1111111 'for 7 segment katoda
Waitus 500
Portb = Lookup(pul , Seg) 'for 7 segment
Waitus 1
If Pul = 0 Then Portd = &B1111111 'for 7 segment katoda
If Pul > 0 Then Portd = &B1111101
Waitus 500
Portb = Lookup(rat , Seg) 'for 7 segment
Waitus 1
If Rat = 0 Then Portd = &B1111111 'for 7 segment katoda
If Rat > 0 Then Portd = &B1111011
Waitus 500
Loop Until Portb..4 = 0
Waktu:
Start Timer1
Nilai:
Incr A
If A = 150 Then Decr Det
If Det = 255 Then Det = 9
If Det = 0 Then Decr Pul
If Pul = 255 Then Pul = 0
If Pul = 0 Then Decr Rat
If Rat = 255 Then Rat = 0
If Det = 0 And Pul = 0 And Rat = 0 Then
Portd = &B1111111
Stop Timer1
Reset Portd.4
Seg: 'nilai 7 segment common katoda
Data &B00111111 , &B00000101 , &B01011011 , &B01001111
Data &B01100101 , &B01101110 , &B01111100 , &B00000111
Data &B01111111 , &B01100111
very need your help please...thanks :D
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.6 ) |
Deanus
Posted: Tue Jan 07, 2014 6:39 am Post subject: |
Hi Kiki,
Quote: | Pul = Pul + 6 ''here the problem..if interrupt we switch 2 time then "pul" is 12 so i want 6+6=2,how to create that |
This code is doing the correct thing, if you want the answer 2 then the code MUST be Pul = Pul + 1, then two times on the switch will be 2!
6+6 cannot = 2
Due to the fact this post has been sitting here a while and unanswered, I don't think we can help you on this one, the logic requirements see all wrong
unless you explain what you want one step at a time.
Regards from a baffled
Deanus[/quote] |
kiki
Posted: Fri Jan 10, 2014 8:54 am Post subject: |
ok , i see...thanks for your information.  |
