$Regfile="m128def.dat"
$Crystal=7372800
$hwstack=128
$swstack=128
$framesize=128
$baud = 9600
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 0
'Init the spi pins 192.168.1.200
Spiinit
Print "Init , set IP to 172.18.0.200" ' display a message
Config Pinb.4 = Output
W5200_nreset Alias Portb.4
Set W5200_nreset
Config Pinb.5 = Input
W5200_nint Alias Portb.5
Reset W5200_nreset
Waitms 1
Set W5200_nreset
Waitms 350
Const Authenticate = 0
Enable INTERRUPTS
Config Tcpip = Noint , Mac = 12.128.12.34.56.78 , Ip = 192.168.1.200 , Submask = 255.255.255.0 , Gateway = 192.168.1.1 , Localport = 1000 , Chip = W5200 , Spi = 1 , Cs = Portb.0
'config pinc.1 = output
'portc.0 = 1
Dim Shtml As String * 15 , Sheader As String * 22
Dim Tempw As Byte
Dim I As Byte , Bcmd As Byte , P1 As Byte , P2 As Byte , Size As Word
Dim Bauth As Byte , Ipcon As Long ' for optional authentication
Dim S As String * 1000 ' was
Dim Buf(1000) As Byte At S Overlay ' this is the same data as S but we can treat it as an array now
Dim Flag As Byte
Dim Tempwsize As Word
Dim Wsize As Word
Dim Bgenerate As Bit
Dim Ihitcounter As Integer
Dim Hits As String * 4
I = 0 ' we use just 1 connection with number 0
Tempw = Socketstat(i , 0) ' get status
Select Case Tempw
Case Sock_established
If Getdstip(i) <> Ipcon Then ' the current client is different then the number stored
Bauth = 0 ' reset authentication bit
Tempw = Socketstat(i , Sel_recv) ' get received bytes
If Tempw > 0 Then ' if there is something received
Bcmd = 0
Tempw = Tcpread(i , S) ' read a line
If Left(s , 3) = "GET" Then
Bcmd = 1 ' GET /index.htm HTTP/1.1
Gosub Page
' store current ip number
Loop Until S = "" ' wait until we get an empty line
#if Authenticate
If Bauth = 0 Then
Tempw = Tcpwrite(i , "HTTP/1.0 401 OK{013}{010}") ' ask for user password
Tempw = Tcpwrite(i , "WWW-Authenticate: Basic realm={034}Ben{039}s HobbyCorner{034}{013}{010}")
Goto Continue
Else
Tempw = Tcpwrite(i , "HTTP/1.0 200 OK{013}{010}")
#else ' no authentication used
Tempw = Tcpwrite(i , "HTTP/1.0 200 OK{013}{010}") 'send ok
#endif
Gosub Stuur ' GET or HEAD or POST feedback so send it
Continue:
Closesocket I ' close the connection
'' End If
Case Sock_close_wait
Closesocket I ' we need to close
Case Sock_closed
I = Getsocket(0 , Sock_stream , 80 , 0) ' get a new socket
Socketlisten I ' listen
End Select
'get html page out of data
Page:
P1 = Instr(s , " ") ' find first space
P1 = P1 + 1 ' 4
P2 = Instr(p1 , S , " ") ' find second space
P2 = P2 - P1
Shtml = Mid(s , P1 , P2) ' dont use too long page names
Shtml = Lcase(shtml) ' make lower case
'send data
Stuur:
Bgenerate = 1 ' by default
' If Shtml = "/index.htm" Then
' Bgenerate = 1
' End If
Tempw = Tcpwrite(i , "Content-Type: text/html{013}{010}")
If Bgenerate = 0 Then
S = "Content-Length: 121{013}{010}"
Tempw = Tcpwritestr(i , S , 255) ' add additional CR and LF
S = "<html><head><title>Easy TCP/IP</title></head><body.<p><b>Page not found</p></body></html>"
Tempw = Tcpwritestr(i , S , 255) ' write data
Else ' we generate the data
Incr Ihitcounter 'increase hitcounter
' count the total characters for Content-Length
Restore Dta1
Wsize = 0
Read S
Wsize = Wsize + Len(s)
Loop Until S = "End"
Hits = Str(ihitcounter)
Wsize = Wsize + Len(hits)
Sheader = "Content-Length: " + Str(wsize) + "{013}{010}"
Tempw = Tcpwritestr(i , Sheader , 255)
Restore Dta1
Read S
If S = "Embedded webserver<br>Hits: " Then
S = S + Hits
Tempw = Tcpwritestr(i , S , 255) ' was 0
' html-code
Dta1:
data "<!DOCTYPE HTML PUBLIC ",&H22,"-//W3C//DTD HTML 4.0 Transitional//EN",&H22,">"
data "<HTML>"
data "<HEAD>"
data " <META HTTP-EQUIV=",&H22,"CONTENT-TYPE",&H22," CONTENT=",&H22,"text/html; charset=windows-1250",&H22,">"
data " <TITLE></TITLE>"
data " <META NAME=",&H22,"GENERATOR",&H22," CONTENT=",&H22,"LibreOffice 4.0.5.2 (Windows)",&H22,">"
data " <META NAME=",&H22,"CREATED",&H22," CONTENT=",&H22,"20131116;22281418",&H22,">"
data " <META NAME=",&H22,"CHANGED",&H22," CONTENT=",&H22,"20131116;22492472",&H22,">"
data "</HEAD>"
data "<BODY LANG=",&H22,"sk-SK",&H22," DIR=",&H22,"LTR",&H22,">"
data "<P><FONT COLOR=",&H22,"#ff0000",&H22,">WELCOME</FONT></P>"
data "<TABLE WIDTH=529 CELLPADDING=0 CELLSPACING=1 STYLE=",&H22,"page-break-inside: avoid",&H22,">"
data " <COL WIDTH=74>"
data " <COL WIDTH=75>"
data " <COL WIDTH=73>"
data " <TR VALIGN=TOP>"
data " <TD WIDTH=74 STYLE=",&H22,"border-top: 1.05pt double #008000; border-bottom: 1.05pt double #008000; border-left: 1.05pt double #008000; border-right: none; padding-top: 0.05cm; padding-bottom: 0.05cm; padding-left: 0.05cm; padding-right: 0cm",&H22,">"
data " <P ALIGN=CENTER>Test</P>"
data " </TD>"
data " <TD WIDTH=75 STYLE=",&H22,"border-top: 1.05pt double #008000; border-bottom: 1.05pt double #008000; border-left: 1.05pt double #008000; border-right: none; padding-top: 0.05cm; padding-bottom: 0.05cm; padding-left: 0.05cm; padding-right: 0cm",&H22,">"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " <TD WIDTH=73 STYLE=",&H22,"border: 1.05pt double #008000; padding: 0.05cm",&H22,">"
data " </TD>"
data " </TR>"
data " <TD WIDTH=74 STYLE=",&H22,"border-top: none; border-bottom: 1.05pt double #008000; border-left: 1.05pt double #008000; border-right: none; padding-top: 0cm; padding-bottom: 0.05cm; padding-left: 0.05cm; padding-right: 0cm",&H22,">"
data " </TD>"
data " <TD WIDTH=75 STYLE=",&H22,"border-top: none; border-bottom: 1.05pt double #008000; border-left: 1.05pt double #008000; border-right: none; padding-top: 0cm; padding-bottom: 0.05cm; padding-left: 0.05cm; padding-right: 0cm",&H22,">"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " <TD WIDTH=73 STYLE=",&H22,"border-top: none; border-bottom: 1.05pt double #008000; border-left: 1.05pt double #008000; border-right: 1.05pt double #008000; padding-top: 0cm; padding-bottom: 0.05cm; padding-left: 0.05cm; padding-right: 0.05cm",&H22,">"
data " </TD>"
data " </TR>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TR>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TD>"
data " </TR>"
data "</TABLE>"
data "<H1><FONT COLOR=",&H22,"#280099",&H22,">WELCOME</FONT></H1>"
data "</BODY>"
data "</HTML>"
Data "End"
