TIMER0, TIMER1, TIMER2 using the "NOSAVE"
radan
PostPosted: Tue Oct 22, 2013 6:29 am    Post subject: TIMER0, TIMER1, TIMER2 using the "NOSAVE" Reply with quote
How to enter and exit the interrupt TIMER0, TIMER1, TIMER2 using the "NOSAVE"?
(BASCOM-AVR version : 2.0.7.6 )
PostPosted: Tue Oct 22, 2013 9:39 am    Post subject: Reply with quote
i think i do not understand the Q since the answer is : the same as without nosave.
on timer0 isr_timer0 nosave
enable timer0
enable interrupts
do
loop
isr_timer0:
'your code here but remember to save sreg and all regs you change when using nosave
'you find code in mcs.lib and other libs just look for RETI which is the return of an ISR
return
also notice in 2077 you can best use a sub routine :
declare sub myisr()
on timer0 myisr()
enable timer0
enable interrupts
do
loop
sub myisr()
'now you can have locals as well
local bSomeByte
End sub
