Using the LM75/LM75-A I2C sensor
Paulvk
PostPosted: Sat Aug 17, 2013 6:54 am    Post subject: Using the LM75/LM75-A I2C sensor Reply with quote
Here are some functions that will set-up and read the LM75/LM75A I2C buss temperature sensors they can set-up and read any of the 8 available addresses for the sensor you can have all 8 connected if you want.
Note I am using the LM75A from NXP which has 11-bit ADC that offers a temperature resolution of 0.125 °C
if you only have 9 bits as in the older versions you will have to shift right 7 bits.
Regards Paul
'--There can be 8 LM75A devices on a buss
'-- HEX  90, 92, 94, 96, 98, 9A, 9C, 9E
'--so lets make it so we can read any one of them
'--we can use this function to return the address
'--or if we have space put the addreses in an EEPROM
'--array of 1 to 8 then use that, this saves 164 bytes of flash
'--eg Dim Lm75add(Cool As Eram Byte
 'Declare Sub Lm75setup(byval Num As Byte)
 'Declare Function Lm75read(byval Num As Byte) As Single
 'Declare Function Getlm75add(byval 75num As Byte)as Byte
'Function Getlm75add(byval 75num As Byte)as Byte
     'Select Case 75num
      'Case 1
      'so Getlm75add(1) will return &H90
      'Getlm75add = &H90
     ' Case 2
     ' Getlm75add = &H92
     ' Case 3
      'Getlm75add = &H94
     ' Case 4
     ' Getlm75add = &H96
     ' Case 5
     ' Getlm75add = &H98
      'Case 6
      'Getlm75add = &H9A
      'Case 7
      'Getlm75add = &H9C
      'Case 8
      'Getlm75add = &H9E
     'End Select
'End Function
Local Waddress As Byte
 'Waddress = Getlm75add(num)        'using the function
 Waddress = Lm75ad(num)                                     'using address stored in EEPROM
I2csend Waddress , &H01
I2csend Waddress , &H18
End Sub
'You need to loop this, to keep reading the temperature
'Do
'Read Temperature
Local Lm75temp As Integer
Local Raddress As Byte
Raddress = Waddress + 1
I2csend Waddress , 0
I2creceive Raddress , Lm75temp , 0 , 2
   Swap Lm75temp                                            'swap the bytes as I2creceive reverses them
  If Lm75temp.15 = 1 Then                                   'its a negative number
    Shift Lm75temp , Right , 5                              ' 5 unused bits plus the sign bit above
    ' Shift Lm75temp , Right , 7 'for older 9 bit devices
   'as its a neagative number the first 5 bits are "1"
    Toggle Lm75temp.15
    Toggle Lm75temp.14
    Toggle Lm75temp.13
    Toggle Lm75temp.12
 '-for 9 bit devices
    'Toggle Lm75temp.11
    'Toggle Lm75temp.10
  Else                                                      'its a positive number
  Lm75read = Lm75temp * 0.125                               'now we have the binary value
End Function
