I bought a module with ENC28J60 and ATMEGA168. Hardware is Tux www
I used the source code from Ben's site but I can not see the device on the network.
Ping does not work. I tried to communicate with the module (such as the flashing of both LED and it works for me.)
I took Ben's code and put together a much larger project which is in the Blog section of the forum http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=10125 This is in modular form which is the "Project Mode of Bascom" I have written a lot of comments to help myself and others so have a look it may help you. Note also I used the Mega1284 as it has the avaliable RAM 16K that was needed for such data intensive work it also comes as a DIP40 which makes it easy to use. Also note there is a problem with Linux based systems yet to be resolved.
If you have the tux board i suggest that you try first the Tux software to be sure that you build the hardware board correct. _________________ www.evertdekker.comBascom code vault
