bzijlstra
Posted: Sun Jul 21, 2013 9:32 am Post subject: Android2Arduino |
Connecting an Android to an Arduino Mega and exchanging information through the USB.
The Arduino Mega should be fitted with an Atmega8u2 or Atmega16u2, FTDI chips will not work.
This does the trick, a OTG-cable
A small program for the Android. Written in Basic4Android.
You need two extra libraries, RandomAccessFile (I have used version 1.50) and USBSerial (I have used version 1.00).
Here a screen shot of the Android program. 4 buttons and when you have a connection pushing one of the 4 buttons will return a reaction from the Arduino.
Here the hardware setup
Basic4Android code:
Code: | 'Android2Arduino Small example made by Ben Zijlstra - 2013
'You need the library: RandomAccessFile. I have used version 1.50 and USBSerial. I used version 1.00
Sub Process_Globals
Dim usb As UsbSerial
Dim astreams As AsyncStreams
End Sub
Sub Globals
End Sub
Sub Activity_Create(FirstTime As Boolean)
Activity.LoadLayout("1")
End Sub
Sub btnOpen_Click
If usb.Open(9600) Then
ToastMessageShow("Connected succesfully",False)
astreams.Initialize(usb.GetInputStream, usb.GetOutputStream, "astreams")
Else
ToastMessageShow("Error opening USB port",False)
End Sub
Sub Astreams_Newdata(buffer() As Byte)
ToastMessageShow(BytesToString(buffer,0,buffer.Length,"UTF8") , False)
End Sub
Sub btnClose_Click
astreams.Close
End Sub
Sub btnSend0_Click
astreams.Write("1".GetBytes("UTF8"))
End Sub
Sub btnSend1_Click
astreams.Write("2".GetBytes("UTF8"))
End Sub
Sub btnSend2_Click
astreams.Write("3".GetBytes("UTF8"))
End Sub
Sub btnSend3_Click
astreams.Write("4".GetBytes("UTF8"))
End Sub
Sub AStreams_Error
astreams.Close
End Sub
Sub Astreams_Terminated
ToastMessageShow("Terminated",False)
astreams.Close
End Sub
Sub Activity_Resume
End Sub
Sub Activity_Pause (UserClosed As Boolean)
End Sub
And the Bascom-AVR-code:
'Connecting an Arduino to an Android
'Arduino receives commands from the Android using the main serial port,
'reacts on commands and returns status information via the same port.
'To be recognized by the Android the Arduino device must be fitted with either
'an Atmega16U2 or Atmega8U2 programmed as an USB-to-serial converter.
'The Android software will not work with FTDI or Prolofic serial based boards.
'Android 3.1 or above attached via USB cable to a suitable Arduino Uno or Mega
'Idea from G.White (Westy53) - Nov. 2012
'Converted to Bascom-AVR by:
'Ben Zijlstra - July 2013.
$regfile = "m2560def.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
Open "Com1:" For Binary As #1
Dim A As Byte , S As String * 2
A = Ischarwaiting(#1)
If A = 1 Then 'we got something
A = Waitkey(#1)
Select Case A
Case 49 : Print #1 , "A";
Case 50 : Print #1 , "B";
Case 51 : Print #1 , "C";
Case 52 : Print #1 , "D";
End Select
Just a simple example.
Have fun
Ben Zijlstra
Bojan
Posted: Sun Jul 21, 2013 1:57 pm Post subject: |
Thanks Ben! |
Posted: Mon Jul 22, 2013 9:59 am Post subject: |
hi Ben
Had no idea about OTG before your post. Thanks for your research and sharing with us.
Your sample that demonstrates how simple it can be. Well done! _________________ Mark |
Posted: Mon Aug 26, 2013 11:25 am Post subject: |
Hi Ben,
You said Quote: |
'an Atmega16U2 or Atmega8U2 programmed as an USB-to-serial converter. |
but how to do that ?
I would like to use a tablet programmed with V4android and a ATMEGA644 (Bascom). the tablet is a nice method to have a big full color screen. I'm looking for the best interface :
USB or BlueTooth.
For BT, I don't know witch module used ?
Thanks for your help
JP |
bzijlstra
Posted: Mon Aug 26, 2013 11:43 am Post subject: atmega8u2 or atmega16u2 |
It is either a 'normal' Arduino with a USB Host shield, or a modern Arduino with an atmega8u2 or atmega16u2 to communicate to the outside world.
The last one works without any modification. You could connect an atmega8u2 or atmega16u2 to your atmega644 to get the same.
Source for atmega8u2 or atmega16u2: all open software...
Have fun
Ben Zijlstra |
techknight
Posted: Thu Aug 29, 2013 4:26 am Post subject: |
You can use the FTDI chips as well, you have to add the correct code in the manifest editor to call the arduino library alongside the usb library inside B4A. Erel has the steps posted over on the B4A forum. |
bzijlstra
Posted: Thu Aug 29, 2013 8:38 am Post subject: |
Merci Ben !
JP |
dawid3143
Meister
Posted: Tue May 06, 2014 10:00 pm Post subject: |
Quote: | For BT, I don't know witch module used ? |
I am using BTM222A or B from Datasphere. Those are class 1 (long range). Also I use HC05 module (class2, ~10m). The BTM is more easy to set-up whereas the HC-05 (05 is important) requires a switch from one pin to 3V to enter programming mode. The advantage with this is that it draws less current. With the bigger BTM I had problems with interference when running from the same power supply as the AVR. BTM222B and HC-05 ca be used up to 921600 baud.
Both BTMs and the HC-05 are listed for 3.3V. However, I am using the BTMs with up to 5.4V (4xNiMH) for years now (not steadily, but quite often). They don't get hot... This is quite comfortable since no level shift is needed. The HC-05 I guess should be operated with 3.3V.
On the Tablet side I also use B4A (full version). However, it took me quite long to get used to it.
If you want to have a large display you might use a PC screen. For PCs running Windows or Linux there is B4J from the same company as B4A and many libraries are compatible. The B4J is free!. You just have to register to the forum. To me, the B4J was easier to learn. With B4J you can very easily communicate with any hardware that creates a virtual USB port. I used FTDI2xx or CP2102 and an I2C-USB interface from ELV or a cheap BT dongle on the PC for wireless, pairing with the BTM or HC-05. Via a TXRX-USB coverter you can directly communicate with any AVR and create your own I"C or SPI interfaces or whatever.
Regards, Meister |
bzijlstra
Posted: Tue May 06, 2014 10:08 pm Post subject: Thanks for the extra info |
Meister
Thanks for the extra info.
Have fun
Ben Zijlstra |
