ADC will not work with CONFIG PORTx = Output in Bootloader?
enniom
PostPosted: Mon Jul 15, 2013 11:59 pm    Post subject: ADC will not work with CONFIG PORTx = Output in Bootloader? Reply with quote
Hello Forum,
This problem took a while to figure out.
I have been successfully using a Bootloader that includes display to a LCD for some time. I use PORTC for the data and PORTA for the control lines (Mega 644P in this case).
Bootloader code snippet:
'Bootloader Mega644p
'Jul 15, 2013
$regfile = "m644pdef.dat"
$hwstack = 80                                               ' default use 32 for the hardware stack
$swstack = 64                                               ' default use 10 for the SW stack
$framesize = 64                                             ' default use 40 for the frame space
'======== [ Bootloader Config ] =================
Disable Interrupts                                          'we do not use ints
$loader = $7800
Const Bootloader_start = $7800
' Bootloader     Hex       $LOADERSIZE
'    8000  none  10000
'    7E00        FC00      $400
'    7C00        F800      $800
'    7800        F000      $1000
'    7000        E000      $2000
Const Maxwordbit = 7                                        'Z7 is maximum bit                                   '
Const Maxword =(2 ^ Maxwordbit) * 2                         '128
Config Porta = Output
Config Portd = Output
'===== [ LCD ] =========================
Wport Alias Portc
Dirport Alias Ddrc
Rport Alias Pinc
Rst Alias Porta.4
Lcdcs Alias Porta.5
E Alias Porta.6
Rw Alias Porta.7
A0 Alias Portd.7
Config Rst = Output
Config Lcdcs = Output
Config E = Output
Config Rw = Output
Config A0 = Output
'rest of bootloader
Goto _reset                                                 'Start new program
The troubleshooting began when I used the ADC in the Main Program. The following sample will demonstrate the problem. The ADC will always return 0 (zero).
'  Config ADC test PORTA
$crystal = 8000000                                          'internal
$baud = 9600
$hwstack = 128
$swstack = 128
$framesize = 128
'Bootloader Config MEGA644P
$loadersize = $1000
'    8000  none  10000
'    7E00        FC00      $400
'    7C00        F800      $800
'    7800        F000      $1000
'    7000        E000      $2000
'Config ADC
Start Adc
Const Adc10bit_volt = 5.0 / 1023
Dim Wadc As Word
Config Single = Scientific , Digits = 1
'Scratchpad
Dim S As Single , Ss As String * 8
' Main
   Wadc = Getadc(0)
   S = Wadc * Adc10bit_volt
   Ss = Str(s)
   Print Wadc ; "  " ; Ss
   Wait 2
End                                                         'end program
I found out that the CONFIG PORTA=Output in the Bootloader affected the ADC function in the main program. It does not appear to be the case that GOTO _Reset actually resets the port configuration.
Only after I removed the CONFIG PORTA line did the ADC work properly in the Main Program. Is there a good explanation? I thought the CONFIG ADC should set the port correctly?
Thanks for any help.
[PS: Similarly, any CONFIG PORTA.x = Output in the main program will not allow the ADC on that pin to function.][/code]
(BASCOM-AVR version : 2.0.7.6 )
PostPosted: Tue Jul 16, 2013 9:16 am    Post subject: Reply with quote
The goto 0 or the reset address (0) just executes the reset address which will setup the registers. It will not setup the IO registers. These are only set to their default state with a hardware reset.
The xmega can do a soft hardware reset. I did not see this option on normal AVR's but you could use the WD for that.
enniom
PostPosted: Wed Jul 17, 2013 2:24 am    Post subject: Reply with quote
Thanks Mark for your help.
I will modify the Bootloader to time-out by Watchdog at the end of flashing then starting the main program.
