' {$STAMP BS2}
' {$PBASIC 2.5}
SDA PIN 0 ' SDA of gyro connected to P0
SCL PIN 1 ' SCL of gyro connected to P1
WRITE_Data CON $D2 ' Request Write operation
READ_Data CON $D3 ' Request Read operation
' Control registers
CTRL_REG1 CON $20
CTRL_REG2 CON $21
CTRL_REG3 CON $22
CTRL_REG4 CON $23
STATUS_REG CON $27
OUT_X_INC CON $A8
X VAR Word
Y VAR Word
Z VAR Word
rawl VAR Word
rawh VAR Word
' Variables for I2C communications
I2C_DATA VAR Byte
I2C_LSB VAR Bit
I2C_REG VAR Byte
I2C_VAL VAR Byte
PAUSE 100 ' Power up delay
' Set up data ready signal
I2C_REG = CTRL_REG3
I2C_VAL = $08
GOSUB I2C_Write_Reg
' Set up "block data update" mode
I2C_REG = CTRL_REG4
I2C_VAL = $80
GOSUB I2C_Write_Reg
' Send the get continuous output command
I2C_REG = CTRL_REG1
I2C_VAL = $1F
GOSUB I2C_Write_Reg
DO
GOSUB Gyro_Get_Raw ' Get XYZ data
' Divide X Y Z, by 114 to reduce noise
IF (X.BIT15) THEN
X = (ABS X) / 114
X = -X
ELSE
X = X / 114
ENDIF
IF (Y.BIT15) THEN
Y = (ABS Y) / 114
Y = -Y
ELSE
Y = Y / 114
ENDIF
IF (Z.BIT15) THEN
Z = (ABS Z) / 114
Z = -Z
ELSE
Z = Z / 114
ENDIF
DEBUG HOME, "RAW X = ",11, SDEC X, CR ' Display data
DEBUG "RAW Y = ",11, SDEC Y, CR
DEBUG "RAW Z = ",11, SDEC Z, CR
PAUSE 250
LOOP
Gyro_Get_Raw:
GOSUB Wait_For_Data_Ready
GOSUB I2C_Start
I2C_DATA = WRITE_DATA
GOSUB I2C_Write ' Read the data starting
I2C_DATA = OUT_X_INC ' at pointer register
GOSUB I2C_Write
GOSUB I2C_Stop
GOSUB I2C_Start
I2C_DATA = READ_DATA
GOSUB I2C_Write
GOSUB I2C_Read
rawL = I2C_DATA ' Read high byte
GOSUB I2C_ACK
GOSUB I2C_Read
rawH = I2C_DATA ' Read low byte
GOSUB I2C_ACK
X = (rawH << 8) | rawL ' OR high and low into X
' Do the same for Y and Z:
GOSUB I2C_Read
rawL = I2C_DATA
GOSUB I2C_ACK
GOSUB I2C_Read
rawH = I2C_DATA
GOSUB I2C_ACK
Y = (rawH << 8) | rawL
GOSUB I2C_Read
rawL = I2C_DATA
GOSUB I2C_ACK
GOSUB I2C_Read
rawH = I2C_DATA
GOSUB I2C_NACK
Z = (rawH << 8) | rawL
GOSUB I2C_Stop
RETURN
'---------I2C functions------------
' Read the status register until the ZYXDA bit is high
Wait_For_Data_Ready:
DO
I2C_REG = STATUS_REG
GOSUB I2C_Read_Reg
LOOP UNTIL ((I2C_DATA & $08) <> 0)
RETURN
' Set I2C_REG & I2C_VAL before calling this
I2C_Write_Reg:
GOSUB I2C_Start
GOSUB I2C_Write
I2C_DATA = I2C_REG
GOSUB I2C_Write
I2C_DATA = I2C_VAL
GOSUB I2C_Write
GOSUB I2C_Stop
RETURN
' Set I2C_REG before calling this, I2C_DATA will have result
I2C_Read_Reg:
GOSUB I2C_Start
GOSUB I2C_Write
I2C_DATA = I2C_REG
GOSUB I2C_Write
GOSUB I2C_Stop
GOSUB I2C_Start
GOSUB I2C_Write
GOSUB I2C_Read
GOSUB I2C_NACK
GOSUB I2C_Stop
RETURN
I2C_Start:
LOW SDA
LOW SCL
RETURN
I2C_Stop:
LOW SDA
INPUT SCL
INPUT SDA
RETURN
I2C_ACK:
LOW SDA
INPUT SCL
LOW SCL
INPUT SDA
RETURN
I2C_NACK:
INPUT SDA
INPUT SCL
LOW SCL
RETURN
I2C_Read:
SHIFTIN SDA, SCL, MSBPRE, [I2C_DATA]
RETURN
I2C_Write:
I2C_LSB = I2C_DATA.BIT0
I2C_DATA = I2C_DATA / 2
SHIFTOUT SDA, SCL, MSBFIRST, [I2C_DATA\7]
IF I2C_LSB THEN INPUT SDA ELSE LOW SDA
INPUT SCL
LOW SCL
INPUT SDA
INPUT SCL
LOW SCL
RETURN |
