bibibo
Posted: Mon Jun 03, 2013 7:44 pm Post subject: WIZ820i0 |
I try to do my first project with TCP/IP. I tried all samples but nothing working. FOr example the code below. Ping working but UDP communication not. I check communication with the Easy TCP/IP
Code: | $Regfile="m1284pdef.dat"
$Crystal=8000000
$hwstack=80
$swstack=64
$framesize=80
$baud = 19200
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 0
Spiinit
Config PinB.2 = Output
W5200_nreset Alias PortB.2
Set W5200_nreset
Config PinB.3 = Input
W5200_nint Alias PortB.3
Reset W5200_nreset
Waitms 1
Set W5200_nreset
Waitms 350
Print "Init TCP"
Config Tcpip = Noint , _
Mac = 0.11.22.33.44.55 , _
Ip = 172.18.0.200 , _
Submask = 255.255.255.0 , _
Gateway = 172.18.0.1 , _
Localport = 5000 , _
Chip = W5200 , _
Spi = 1 , _
Cs = PortB.4
Dim Result As Word ' result
Dim S(255) As Byte
Dim Sstr As String * 255
Dim Temp As Byte , Temp2 As Byte ' temp bytes
Const Showresult = 1
Print "UDP demo"
Dim Ip As Long
Ip = Maketcp(172.18.0.51) 'assign IP num
'like with TCP, we need to get a socket first
Idx = Getsocket(idx , $02 , 5000 , 0) ' get socket for UDP mode, specify port 5000
Temp = Inkey() ' wait for terminal input
If Temp = 27 Then ' ESC pressed
Sstr = "Hello"
Result = Udpwritestr(ip , 5000 , Idx , Sstr , 255)
Elseif Temp = 32 Then 'space
Waitms 200
Dim Tel As Long : Incr Tel
Sstr = "0000000000111111111122222222223333333333 " + Str(tel)
Result = Socketstat(idx , Sel_recv) ' get number of bytes waiting
If Result > 0 Then
Print "Bytes waiting : " ; Result
Udpreadheader Idx ' read the udp header
#if Showresult
Print
Print Peersize ; " " ; Peeraddress ; " " ; Peerport ' these are assigned when you use UDPREAD
Print Ip2str(peeraddress) ' print IP in usual format
#endif
If Peersize > 0 Then ' the actual number of bytes
Print "read" ; Peersize
Temp = Udpread(idx , S(1) , Peersize) ' read the result
#if Showresult
For Temp = 1 To Peersize
Print S(temp) ; " " ; ' print result
Print "done"
#endif
Result = Udpwrite(ip , Peerport , Idx , S(1) , Peersize) ' write the received data back
'the sample above waits for data and send the data back for that reason temp2 is subtracted with 8, the header size
End |
bzijlstra
Posted: Mon Jun 03, 2013 8:57 pm Post subject: W5200 SNTP example... |
With the W5200 I got this running:
Code: | 'Arduino Duemilanove test - Atmega328p
'W5200 - SNTP works
$regfile "m328pdef.dat"
$crystal = 16000000
$framesize = 80
$loadersize = &H800
'Configuration Of The SPI bus
'Init the spi pins
Spiinit
Config Tcpip = Int0 , Mac = 12.128.12.34.56.78 , Ip = 192.168.0.70 , Submask = 255.255.255.0 , Gateway = 192.168.0.1 , Localport = 1000 , Tx = $55 , Rx = $55 , Chip = W5200 , Spi = 1 ', Cs = Portb.2
Print "Init done"
Dim Var As Byte 'for i2c test
Print "SNTP demo"
Print "Connecting to : " ; Ip2str(ip)
'we will use Dutch format
'toggle the variable
Toggle Var
Waitms 5000
' Print Idx ; Lsntp
Check also the bascomforum.de Six1 made some code for the WIZ820io in Bascom-AVR.
Have fun
Ben Zijlstra |
bibibo
Posted: Mon Jun 03, 2013 9:21 pm Post subject: |
I do not know. Maybe there is a hardware problem. |
Posted: Mon Jun 03, 2013 9:26 pm Post subject: |
make sure reset time is long enough. i know MAK3 had a problem and the longer reset solved it.
Reset W5200_nreset
Waitms 1
Set W5200_nreset
Waitms 350 _________________ Mark |
bibibo
Posted: Tue Jun 04, 2013 3:52 pm Post subject: |
it did not help |
bibibo
Posted: Tue Jun 04, 2013 8:19 pm Post subject: |
So, my problem was solved. I had connected ISP programmer parallel to WIZ module. |
bzijlstra
Posted: Tue Jun 04, 2013 8:45 pm Post subject: wiz820io |
Great to hear!!
Have fun
Ben Zijlstra |
bibibo
Posted: Wed Jun 05, 2013 7:12 pm Post subject: |
so, One more problem. I try the sample code servertest_W5200.bas but I cannot connect to WIZ by tool Easy TCP/IP. If I mark check connect, the mark removes itself. |
MAK3
bibibo
Posted: Thu Jun 06, 2013 7:05 am Post subject: |
could someone explain me what is it socket ? Why are there 0 - 7 socket ?
Code: | For Idx = 0 To 7
Result = Socketstat(idx , 0) |
MAK3
Posted: Thu Jun 06, 2013 8:34 am Post subject: |
because the W5200 Chip on the WIZ820io provide 8 sockets:
http://www.wiznet.co.kr/Sub_Modules/en/product/Product_Detail.asp?cate1=5&cate2=7&cate3=56&pid=1144
iEthernet W5200 ? Fast SPI Ethernet Controller
- High Speed Serial Peripheral Interface (SPI MODE 0, 3)
- Hardwired TCP/IP Protocols : TCP, UDP, ICMP, IPv4 ARP, IGMP, PPPoE, Ethernet
- 10BaseT/100BaseTX Ethernet MAC/ PHY embedded
- Auto Negotiation ( Full and half duplex, 10 and 100-based )
- Auto MDI/MDIX (Straight-through or Crossover)
- ADSL connection (with support PPPoE Protocol & PAP/CHAP Authentication mode)
- 8 independent sockets simultaneously
- Internal 32Kbytes Memory for Tx/Rx Buffers
- Multi-function LED outputs (Full/Half duplex, Link, Speed)
- Power down mode
- Wake on LAN
- 0.18 μm CMOS technology
- 3.3V operation with 5V I/O signal tolerance
- Lead-Free Package
- Small & Compace 48 Pin QFN Package |
bibibo
Posted: Thu Jun 06, 2013 7:04 pm Post subject: |
Maybe I don't understand network communication. I try send a string from PC to atmega with UDP protocol. If I press ESC, atmega send the string Hello to PC. It is ok but then I think that the program stay before condition Result because Result = 0. When will value of Result > 0 ?
Code: | $Regfile="m644pdef.dat"
$Crystal=8000000
$hwstack=128
$swstack=128
$framesize=128
$baud = 9600
'Init the spi pins
Spiinit
Print "Init , set IP to 172.18.0.200" ' display a message
Config Pinb.2 = Output
W5200_nreset Alias Portb.2
Set W5200_nreset
Config Pinb.3 = Input
W5200_nint Alias Portb.3
Reset W5200_nreset
Waitms 1
Set W5200_nreset
Waitms 350
Enable INTERRUPTS
Config Tcpip = Noint , Mac = 12.128.12.34.56.78 , Ip = 172.18.0.200 , Submask = 255.255.255.0 , Gateway = 172.18.0.1 , Localport = 1000 , Chip = W5200 , Spi = 1 , Cs = Portb.4
'config pinc.1 = output
'portc.0 = 1
Dim S(80) As Byte
Dim Sstr As String * 20
'When you use UDP, you need to dimension the following variables in exactly the same order !
Declare Function Ipnum(ip As Long) As String ' a handy function
UDPREADHEADER idx
Sstr = "Hello"
Result = Udpwritestr(172.18.0.51 , 5000 , Idx , Sstr , 255)
print result
If Result > 0 Then
Temp2 = Result - 8 'the first 8 bytes are always the UDP header which consist of the length, IP number and port address
Temp = Udpread(idx , S(1) , Result) ' read the result
For Temp = 1 To Temp2
Print
Print Ipnum(peeraddress) ' print IP in usual format
Result = Udpwrite(172.18.0.51 , Peerport , Idx , S(1) , Temp2) ' write the received data back
'this function can be used to display an IP number in normal format
Local T As Byte , J As Byte
Ipnum = ""
For J = 1 To 4
T = Ip And 255
Ipnum = Ipnum + Str(t)
If J < 4 Then Ipnum = Ipnum + "."
Shift Ip , Right , 8
End Function
bibibo
Posted: Thu Jun 06, 2013 7:59 pm Post subject: |
so, If I press ESC, ATMEGA sends to PC "Hello". If I send the string "test" from PC to ATMEGA, the string comes back to PC but why console printing not "Bytes waiting : ", recieved string " test" ? |
bibibo
Posted: Thu Jun 06, 2013 9:00 pm Post subject: |
the problem is solved. I used Putty terminal instead of Bascom terminal. |
