GPS processing and status display
doncarlos
PostPosted: Sun May 26, 2013 9:48 pm    Post subject: GPS processing and status display Reply with quote
Hello!
I want to share my little program. This is not a final project but the core functions are complete. I'm using a GPS module from adafruit http://www.adafruit.com/products/746 and its working great, even indoors. The basic idea of processing the NMEA sentences comes from forum member Glena. Thanks for it! The code have three different parts, one for displaying coordinates, time, DOP values, speed, etc., one for displaying the parameters of the satellites in view like PRN number, azimuth, elevation and SNR values. These values can be used for making an SNR bargraph for the tracked satellites (which will be a further improvement). The third function is drawing a skyplot with icons and PRN numbers. I'm using a display with a PCF8833 controller from an old Nokia 3100.
Here is the code (sorry for the multilingual variable names):
'GPS Info by doncarlos with atmega128 and PCF8833 display for processing standard NMEA data
$regfile = "m128def.dat"
$crystal = 11059200
$hwstack = 256
$swstack = 256
$framesize = 256
$lib "lcd-pcf8833BR2.lbx"
Config Graphlcd = Color , Controlport = Portc , Cs = 1 , Rs = 0 , Scl = 3 , Sda = 2
'######################## Color definitons ###################################
Const Blue = &B00000011
Const Yellow = &B11111100
Const Red = &B11100000
Const Green = &B00011100
Const Black = &B00000000
Const White = &B11111111
Const Brightgreen = &B00111110
Const Darkgreen = &B00010100
Const Darkred = &B10100000
Const Darkblue = &B00000010
Const Brightblue = &B00011111
Const Orange = &B11111000
Config Com1 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Com2 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Serialin = Buffered , Size = 250 , Bytematch = 13    ' GPS Buffer
Dim Gps_data_flag As Byte
Dim Strbytes(252) As Byte
Dim Gpsline As String * 251 At Strbytes(1) Overlay          ' NMEA sentence holder
Dim Gpsline_t As String * 251
Dim Strlen As Byte
Dim Index As Byte
Dim Chksum As Byte
Dim Gps_chksum As String * 2
Dim Gps_chksum_b As Byte
Dim Dollar As String * 1
Dim Z As Byte
Dim Gps_adatok(21) As String * 15                                'Array for storing various GPS data
Dim Gpstime_s As String * 10
Dim Gpsdate_s As String * 10
Dim Gpslat_s As String * 10
Dim Gpslon_s As String * 10
Dim Pos_status As String * 1 , Nofix As Bit
Dim Dms_lat As String * 15 , Dms_long As String * 15
Dim We As String * 1 , Ns As String * 1
Dim Pdop As String * 4 , Hdop As String * 4 , Vdop As String * 4 , Magassag As String * 6 , Sebesseg As String * 7
Dim Fix_type(4) As String * 8 , Fix_szam As Byte
Dim Sat_track As String * 2
Dim Timezone As Byte
Dim Perc As String * 2 , Mp As String * 2 , Ora As String * 2 , Ora_b As Byte            'Time values: min, sec, hour
Dim Nap As String * 2 , Honap As String * 2 , Ev As String * 2                                 'Date values: date, month, year
Dim Ido As String * 8 , Datum As String * 8
Dim Sentence_count As Byte , Sentence_num As Byte , Satinview As Byte
Dim Szamlalo As Byte , Szamlalo2 As Byte , Cim As Byte , L As Byte , K As Byte , Cim_temp As Byte , Lineindex As Byte  'some indexing values
Dim Satinfo(64)as String * 3        'Array for the PRN display data (PRN, Azimuth, Elevation, SNR)
Dim I As Byte , H As Byte
Dim Index_temp1 As Byte , Index_temp2 As Byte , Dy As Byte , Dx As Byte            'More indexing values
Dim Pr_number As String * 2 , Ele As String * 2 , Azi As String * 3 , Snr As String * 2
Dim Azi_single As Single , Ele_int As Integer
Dim Ticker As Byte
Timezone = 2        'Modify this for setting your timezone
Declare Function Dmtodms(byval Szog_string As String) As String
Declare Sub Skyplot(azimuth As Single , Byval Elevation As Integer , Prn As String * 2 , Byval Ncolor As Byte)
'######################### LCD Init ############################################
Glcdcmd &H21
Glcdcmd &H36
Glcddata &H48                                               '40 = RGB or 48 = BGR
Open "Com2:" For Binary As #2
Cls
Print "Serial1 init"
Print #2 , "Serial2 init"
Setfont Color8x8
Lcdat 63 , 30 , "GPS" , Black , White
Cls
Fix_type(1) = "SPS fix"
Fix_type(2) = "DGPS fix"
Fix_type(3) = "PPS fix"
Fix_type(4) = "RTK fix"
Szamlalo = 1
Szamlalo2 = 1
'!!!!!!!!!!!!!!!!!!  For now this is the function selector !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'!!!!!!!!!!!!!!!!!  uncomment one of the gotos to select  !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!! a function, if both commented out the text display will run  !!!!!!!!!!!!!!!!!!
'Goto Sky
'Goto Prn_snr
Lcdat 4 , 2 , "GPS Ido:" , Black , White
Lcdat 14 , 2 , "Koordinatak:" , Black , White
Lcdat 44 , 2 , "Elev:" , Black , White
Lcdat 54 , 2 , "Speed:" , Black , White
Szoveges:
   If Gps_data_flag > 0 Then Gosub Processgps
   If Pos_status = "V" Then
      If Nofix = 1 Then Goto Szoveges
      Nofix = 1
      Lcdat 74 , 2 , "     NO FIX!     " , Black , White
      Lcdat 4 , 66 , "         " , Black , White
      Lcdat 24 , 2 , "                " , Black , White
      Lcdat 34 , 2 , "                " , Black , White
      Lcdat 44 , 56 , "                " , Black , White                        'clearing the display
      Lcdat 54 , 56 , "                " , Black , White                        'this is faster then a cls
      Lcdat 64 , 2 , "                " , Black , White
      Lcdat 94 , 2 , "                " , Black , White
      Lcdat 104 , 2 , "                " , Black , White
      Lcdat 114 , 2 , "                " , Black , White
   Else
      Nofix = 0
      Ora = Mid(gpstime_s , 1 , 2)
      Perc = Mid(gpstime_s , 3 , 2)
      Mp = Mid(gpstime_s , 5 , 2)
      Nap = Mid(gpsdate_s , 1 , 2)
      Honap = Mid(gpsdate_s , 3 , 2)
      Ev = Mid(gpsdate_s , 5 , 2)
      Ora_b = Val(ora) + Timezone
      If Ora_b > 24 Then Ora_b = Ora_b - 24
      Ora = Str(ora_b)
      Ido = Ora + ":" + Perc + ":" + Mp
      Datum = Ev + "." + Honap + "." + Nap
      Dms_lat = Dmtodms(gpslat_s)
      Dms_long = Dmtodms(gpslon_s)
      Lcdat 4 , 66 , Ido , Black , White
      Lcdat 24 , 2 , Ns ; " " ; Dms_lat , Black , White
      Lcdat 34 , 2 , We ; " " ; Dms_long , Black , White
      Lcdat 44 , 56 , Magassag ; "M"
      Lcdat 54 , 56 , Sebesseg ; "Km/h"
      Lcdat 64 , 2 , "Sat trk: " ; Sat_track
      Lcdat 74 , 2 , Fix_type(fix_szam) ; "        "
      Lcdat 94 , 2 , "PDOP: " ; Pdop ; "      "
      Lcdat 104 , 2 , "HDOP: " ; Hdop ; "      "
      Lcdat 114 , 2 , "VDOP: " ; Vdop ; "      "
Prn_snr:
Cls
   Lcdat 4 , 2 , "PRN" , Black , White : Lcdat 4 , 34 , "Ele" , Black , White : Lcdat 4 , 70 , "Azi" , Black , White : Lcdat 4 , 102 , "SNR" , Black , White
   For I = 1 To Satinview
      For H = 1 To 4
         Index_temp1 = I - 1
         Index_temp1 = Index_temp1 * 4
         Index_temp2 = H + Index_temp1
         Dy = I - 1
         Dx = H - 1
         Dy = Dy * 8                                        '12
         Dy = Dy + 15
         Dx = Dx * 35
         Dx = Dx + 4
         Setfont Color5x5
         Lcdat Dy , Dx , Satinfo(index_temp2)
         Setfont Color8x8
      Next H
   Next I
Sky:
Cls
Circle(66 , 66) , 60 , Black                                'Drawing the skyplot background
Circle(66 , 66) , 40 , Black                                '            |
Circle(66 , 66) , 20 , Black                                '            |
Line(66 , 0) -(66 , 132) , Black                            '          |
Line(0 , 66) -(132 , 66) , Black                            '          ˇ
         Index_temp1 = I - 1
         Pr_number = Satinfo(1 + Index_temp1)
         Ele = Satinfo(2 + Index_temp1) : Ele_int = Val(ele)
         Azi = Satinfo(3 + Index_temp1) : Azi_single = Val(azi)
         If Azi_single <> 0 And Ele_int <> 0 And Pr_number <> "" Then
         'Call Skyplot(azi_old , Ele_old , Pr_number , White)
         Call Skyplot(azi_single , Ele_int , Pr_number , Red)
         'Azi_old = Azi_single : Ele_old = Ele_int
   Next I
Waitms 250
Serial0charmatch:
   Pushall
   Incr Gps_data_flag                                       'Increment the NMEA sentence counter
   Popall
Processgps:
Decr Gps_data_flag
   Dollar = Inkey()                                         'Start finding
   If Dollar = "" Then Return
Loop Until Dollar = "$"
Input Gpsline Noecho
Strlen = Len(gpsline)
Chksum = 0
Gps_chksum_b = 0
Strlen = Strlen - 3
For Index = 1 To Strlen
   Chksum = Chksum Xor Strbytes(index)                      'Checksum generation
Next Index
Gps_chksum = Right(gpsline , 2)
Gps_chksum_b = Hexval(gps_chksum)
If Chksum = Gps_chksum_b Then                               'If the checksum matches then we can process the right data
    Gpsline_t = Left(gpsline , Strlen)
    Z = Split(gpsline_t , Gps_adatok(1) , ",")
    Select Case Gps_adatok(1)
      Case "GPRMC"                                          'position and time data
         Pos_status = Gps_adatok(3)
         If Pos_status = "A" Then
            Gpstime_s = Gps_adatok(2)
            Gpsdate_s = Gps_adatok(10)
            Gpslat_s = Gps_adatok(4)
            Gpslon_s = Gps_adatok(6)
            We = Gps_adatok(7)
            Ns = Gps_adatok(5)
      Case "GPGGA"                                          'fix type, tracked sat number and elevation
         Fix_szam = Val(gps_adatok(7))
         If Fix_szam <> 0 Then Magassag = Gps_adatok(10)
         Sat_track = Gps_adatok(8)
      Case "GPGSA"                                          'DOP values
         Pdop = Gps_adatok(16)
         Hdop = Gps_adatok(17)
         Vdop = Left(gps_adatok(18) , 4)
      Case "GPVTG"                                          'speed
         Sebesseg = Gps_adatok(8)
      Case "GPGSV"
         Satinview = Val(gps_adatok(4))
         Sentence_count = Val(gps_adatok(2))
         Sentence_num = Val(gps_adatok(3))
         If Sentence_num <= Sentence_count Then
            If Sentence_num = Szamlalo Then
             For L = 1 To 4                                    'Filling up the satinfo array
               If Szamlalo2 > Satinview Then
                  Szamlalo2 = 1
                  Exit For
               Else
                  For K = 1 To 4
                     Cim_temp = L - 1
                     Cim_temp = Cim_temp * 4
                     Cim = K + Cim_temp
                     Lineindex = K + Cim_temp
                     Lineindex = Lineindex + 4
                     Cim_temp = Sentence_num - 1
                     Cim_temp = Cim_temp * 16
                     Cim = Cim + Cim_temp
                     Satinfo(cim) = Gps_adatok(lineindex)
                  Next K
                  Incr Szamlalo2
             Next L
             If Szamlalo = Sentence_count Then
               Szamlalo = 1
             Else
               Incr Szamlalo
      Case Else
    End Select
Function Dmtodms(szog_string As String) As String 'function to convert the nmea degrees and miutes to degrees minutes and seconds
Local Szogmp As Single
Local Fok_s As String * 3 , Szogperc_s As String * 2 , Szogmp_s As String * 5
If Len(szog_string) = 9 Then
   Fok_s = Left(szog_string , 2)
   Szogperc_s = Mid(szog_string , 3 , 2)
   Szogmp_s = Right(szog_string , 5)
   Szogmp_s = "0" + Szogmp_s
   Szogmp = Val(szogmp_s)
   Szogmp = Szogmp * 60
   Szogmp_s = Fusing(szogmp , "#.##")
If Len(szog_string) = 10 Then
   Fok_s = Left(szog_string , 3)
   Szogperc_s = Mid(szog_string , 4 , 2)
Dmtodms = Fok_s + Chr(127) + Szogperc_s + Chr(39) + Szogmp_s + Chr(34)
End Function
Sub Skyplot(azimuth As Single , Elevation As Integer , Prn As String * 2 , Ncolor As Byte)
Local X As Single , Y As Single
Local X1 As Integer , Y1 As Integer
Local X2 As Integer , Y2 As Integer
Local Azimuth_rad As Single
Local Temp As Single , Temp2 As Single
   Temp = Azimuth - 90                                      'Turning the polar coordinate system with 90°
   Azimuth_rad = Deg2rad(temp)
   Temp2 = 90 - Elevation                                   'Inverting the elevation values because for a normal polar coordinate system 90° of elevation would be the furthest and in a skyplot the 90° is the center of the coordinate system
   Temp2 = Temp2 * 0.666667                                 'Scaling down the elevation value because the small screen space
X = Cos(azimuth_rad)
X = X * Temp2                                               'or * Elevation if you have a bigger screen to work with
X = X + 66
X1 = X
X2 = X1 - 4
Y = Sin(azimuth_rad)
Y = Y * Temp2                                               'or * Elevation
Y = Y + 63
Y1 = Y
Y2 = Y1 - 4
Lcdat Y2 , X2 , Chr(132) , Ncolor , White                   'GPS sat icon drawing
Y2 = Y2 + 9 : X2 = X2 - 1                                   'PRN number align
Setfont Color5x5
Lcdat Y2 , X2 , Prn                                         'Prn
Setfont Color8x8
End Sub
Close #2
'fonts
$include "color8x8.font"
$include "color5x5.font"
I attach my font file because i draw a GPS satellite icon at the 132 position.
Feel free to ask anything and if someone wants i will take some pictures. And of course any improvements, error corrections, suggestions are welcomed!
View user's profile MSN Messenger
PostPosted: Sun May 26, 2013 10:26 pm    Post subject: Reply with quote
thank you for sharing. It is a good framework to get started quickly.
One question : can you include the source in the ZIP file?
And maybe you can upload a screen shot of the LCD. Very Happy
doncarlos
PostPosted: Sun May 26, 2013 11:13 pm    Post subject: Reply with quote
Sure! I will take some pictures this afternoon and add them to the end of the post. And i re-upload the zip with the source code.
doncarlos
PostPosted: Tue May 28, 2013 3:58 pm    Post subject: Reply with quote
Sorry guys no pictures. I successfully fried my m128, pcf8833 display and mkII programmer.
PostPosted: Tue May 28, 2013 8:15 pm    Post subject: Reply with quote
sorry to hear that. how was that possible? the mkII is protected, are you sure it is defect?
hope the USB port still works.
doncarlos
PostPosted: Tue May 28, 2013 8:47 pm    Post subject: Reply with quote
I had a ywrobot breadboard power supply and its both voltage regulators gave up... So at the 3.3V line I had 5V and in the 5V line I had 12.5V...
My mkII is a clone and now it can't communicate with the avrs, but I can still flash its firmware (it have an at90usb168) so its not completely dead, I contacted the guy who makes them and he sad, maybe the GTL2003 levelshifter burned out. I really hope so Rolling Eyes
And I can say I'm still luck because my xbee and gps modules are survived (thanks for the integrated regulators)!
PostPosted: Tue May 28, 2013 9:12 pm    Post subject: Reply with quote
yes that is a receipt for frying.
use a fuse and a transient suppressor. it will help in cases like this.
doncarlos
PostPosted: Sun Jun 02, 2013 4:49 pm    Post subject: Reply with quote
Here are the pictures! I had more luck than I thought! Smile My lcd survived the over voltage and I can round up a m32 which has enough sram to run my code.
Basic information:
Skyplot:
Satellite info:
In action:
PostPosted: Mon Jun 03, 2013 10:00 pm    Post subject: Reply with quote
great ! good news. yes sometimes it is remarkable what they can survive. i remember i inserted a chip 180 degreed rotated. (90 would be really remarkable). it became hot and after i discovered the silly mistake, i inserted it properly and it worked.
thanks for the pictures. it looks very good. like the skyplot.
Paulvk
PostPosted: Tue Jun 04, 2013 12:00 am    Post subject: Reply with quote
Hello doncarlos
Its amazing what you can grow in a plastic bread board.
I also like the skyplot, just can not get rid of the feeling that there is something missing at the bottom.... To shoot them down with Very Happy
Regards Paul
doncarlos
PostPosted: Tue Jun 04, 2013 8:39 am    Post subject: Reply with quote
Thanks for both of you!
And yes the skyplot is a little empty (not in the air defense way Laughing ), i would really like a bigger screen and add the satelite snr graph under the skyplot, but i can't get my SSD1289 display working.
Iskandar20
PostPosted: Fri Jun 07, 2013 6:34 pm    Post subject: Reply with quote
if me work with module gps series PMB 648.
how to write a program in bascom to retrieve data from this module??
doncarlos
PostPosted: Sat Jun 08, 2013 12:12 pm    Post subject: Reply with quote
If your gps module outputs standard NMEA data you can use the code above. You only need to set the correct baudrate to communicate with the modul. You can change the lcdat commands with print then you can use terminal emulator to display the processed data.
Iskandar20
PostPosted: Sat Jun 08, 2013 1:39 pm    Post subject: Reply with quote
for example doncarlos?
doncarlos
PostPosted: Sat Jun 08, 2013 4:34 pm    Post subject: Reply with quote
After the "Szoveges" label insert this:
      Nofix = 1
      Print "No fix!"
   Else
      Nofix = 0
      Ora = Str(ora_b)
      Print Ido
      Print Ns ; " " ; Dms_lat
      Print We ; " " ; Dms_long
      Print Magassag ; "M"
      Print Sebesseg ; "Km/h"
      Print "Sat trk: " ; Sat_track
      Print Fix_type(fix_szam)
      Print "PDOP: " ; Pdop
      Print "HDOP: " ; Hdop
      Print "VDOP: " ; Vdop
