Timer resets after interrupt?
dewey
PostPosted: Sun Oct 05, 2014 12:53 am    Post subject: Timer resets after interrupt? Reply with quote
Hi
I'm experiencing unexpected behavior: When returning from an ISR, Timer1 resets to 0 and program flow jumps to the very top of the program, not back to where the ISR was triggered from. Then, the program executes one line of code (a Const ststement in my case, not nearly enough to overflow Timer1 again), then jumps right back to the ISR again! (As seen by the BASCOM simulator). Are both of these effects normal? I would have expected program flow to return to where it left and Timer1 to be what I set it at (plus a little) before it left the ISR (roughly 19050). Thanks for any help.
Here is my code:
'Main Program
Enable Interrupts                                           'Turn on global interrupt ability
Enable TIMER1
On TIMER1 PL_tone_ISR
Waitms 1000   '<-- Trigger timer1 overflow and ISR
PL_tone_ISR:
   TIMER1 = 19000
   If PLToneWavePosition = 3 Then                           'Wave position varies from 0 to 3.  At the top of the wave = 3
      PLToneWaveDirection = Down                            '0 = a wave heading down, 1 = up
      PLToneWavePosition = 2
      WalshBit1 = 1
      WalshBit2 = 0
   ElseIf PLToneWavePosition = 2 Then
      If PLToneWaveDirection = Down Then                    'Moving from wave position 2 to 1
         PLToneWavePosition = 1
         WalshBit1 = 0
         WalshBit2 = 1
      Else                                                  'Moving from 2 to 3
         WalshBit1 = 1
         WalshBit2 = 1
Return  '<-- Program execution returns from here to the very top of the file, processes 1 line, then jumps right back to the top of the ISR
i.dobson
PostPosted: Sun Oct 05, 2014 10:09 am    Post subject: Reply with quote
What CPU are you using?
What are scaler are you using for timer1?
Do you see this on real Hardware or just the Simulator?
Is you Hardware/Software/Frame stack large enough?
Regards
Ian Dobson
http://www.planet-ian.com
Evert :-)
PostPosted: Sun Oct 05, 2014 11:45 am    Post subject: Reply with quote
You need to give as some more info, clock speed, config timer, stack, cpu.
