call sub in interrupt
uga237
PostPosted: Tue Mar 26, 2013 3:37 pm    Post subject: call sub in interrupt Reply with quote
$regfile = "xm256A3def.dat"
$crystal = 32000000
$hwstack = 1024
$swstack = 1024
$framesize = 1024
Const Pda_pcb_ver = 2
Config Submode = New
Config Osc = Enabled , Pllosc = Disabled , Extosc = Disabled , 32khzosc = Disabled , 32mhzosc = Enabled '32MHz
'configure the systemclock
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 '32MHz
Declare Sub Func_1(byval Byte_ctr As Word , Byval Byte_ctr1 As Word , Byval Byte_ctr2 As Word , Byval Byte_ctr3 As Word)
Declare Sub Func_2(byval Byte_ctr As Word , Byval Byte_ctr1 As Word , Byval Byte_ctr2 As Word , Byval Byte_ctr3 As Word)
Declare Sub Pilik()
'INIT
'Buzz init
#if Pda_pcb_ver = 2
Buzz Alias Portc.1
Config Buzz = Output
Const Buzz_on = 1
Const Buzz_off = 0
Buzz = Buzz_off
#endif
'End Buzz init
'TC
Config Tcf0 = Normal , Prescale = 64
Tcf0_per = 1000 ' 500Hz
On Tcf0_ovf Tcf0_isr
Enable Tcf0_ovf , Lo 'Enable this Interrupt as Lo Level Interrupt
'End TC
'=============MAIN==============
Config Priority = Roundrobin , Vector = Application , Lo = Enabled 'Enable Lo Level Interrupts
Call Pilik()
Call Pilik()
Call Func_1(1 , 2 , 3 , 4 )
Waitus 500
Tcf0_isr:
Call Func_2(1 , 2 , 3 , 4 )
If Byte_ctr <> 1 Then
Call Pilik()
If Byte_ctr1 <> 2 Then
Call Pilik()
If Byte_ctr2 <> 3 Then
Call Pilik()
If Byte_ctr3 <> 4 Then
Call Pilik()
End Sub
nop
End Sub
Sub Pilik()
Sound Buzz , 90 , 1000
Sound Buzz , 90 , 500
Sound Buzz , 90 , 700
End Sub
Some time hear "pilik"
(BASCOM-AVR version : 2.0.7.6 )
uga237
PostPosted: Tue Mar 26, 2013 3:42 pm    Post subject: Reply with quote
Avr dbg
PostPosted: Tue Mar 26, 2013 4:05 pm    Post subject: Reply with quote
when calling user functions/subs from interrupts you need :
$frameprotect = 1
uga237
PostPosted: Tue Mar 26, 2013 4:11 pm    Post subject: Reply with quote
Thank you. I search solve this error 7 days... but it easy )))
Why it is off by default in 2076?
PostPosted: Tue Mar 26, 2013 4:17 pm    Post subject: Reply with quote
because it is not recommended to call user subs from an interrupt. when it would be on by default, it generates more code.
so this option is only for the user that really want to call user functions from interrupts which pass variables byval.
uga237
PostPosted: Tue Mar 26, 2013 4:31 pm    Post subject: Reply with quote
"because it is not recommended to call user subs from an interrupt." - filosofy )
In r3,sreg
cli
Out sreg,r3
This no big code )
may be add info about "By default the frame protection is off. " in FAQ or "Newbie problems"?
