Atmega32 and Wiznet W5100
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
jakub.jnm
PostPosted: Tue Mar 26, 2013 10:05 am    Post subject: Atmega32 and Wiznet W5100 Reply with quote
Hi there!
I am trying to run Wiznet W5100 with Atmega32. I connected SCK, MISO,MOSI,SS,INT pins.
I tried all sample codes, but there is still the same problem. During the compilation i obtained this message:
-Library file not found C:Program Files....\Bascom-AVR\LIB\TCPIP-W5100.LIB
I tried to find this library on the internet but i was unsuccessful.
Also tried many examples code from there, but there is the same problem.
Can anybody help me?
PostPosted: Tue Mar 26, 2013 10:18 am    Post subject: Reply with quote
can you post the sample you used?
the lbx should be used, not the lib.
jakub.jnm
PostPosted: Tue Mar 26, 2013 10:43 am    Post subject: Reply with quote
$regfile = "m8def.dat" '
$crystal = 8000000 '
$baud = 9600 '
$hwstack = 64
$swstack = 64
$framesize = 64
Config Spi = Hard , Interrupt = On , Data Order = Msb , Master = Yes , Polarity = Low , _
Phase = 0 , Clockrate = 4 , Noss = 0
Spiinit
Config Tcpip = Int0 , Mac = 12.128.12.34.56.78 , Ip = 192.168.2.16 , Submask = 255.255.255.0 , _
Gateway = 192.168.2.1 , Localport = 5000 , Tx = $55 , Rx = $55 , Chip = W5100 , Spi = 1
Dim Bclient As Byte ' socket number
Dim Idx As Byte
Idx = 0 ' only 1 socket
Dim Result As Word
Config Portc = Output ' for status indicator
Dim Status As Byte
Dim Status_old As Byte
'----------------- init ----------------------------------
Osccal = &H90
'----------------- Main ----------------------------------
Wait 1 ' nur 1 Socket
Print "Starting...."
Waitms 200
Result = Socketstat(idx , 0) ' get status
Status = Result
If Status <> Status_old Then
Portc = Not Status
Print "Status: " ; Status
Status_old = Status
Select Case Result
Case Sock_established
Print "Connected"
Case Sock_close_wait
Closesocket Idx
Case Sock_closed
Bclient = Getsocket(idx , Sock_stream , 5000 , 0) ' get socket for server mode
Socketlisten Idx
Case Sock_listen
nop
Case Else
Closesocket Idx
End Select
It's sample which is there on forum
PostPosted: Tue Mar 26, 2013 10:48 am    Post subject: Reply with quote
please compile the sample and attach a ZIP file with the rpt, err and bas files.
the problem you have is not possible with the shown sample.
jakub.jnm
PostPosted: Tue Mar 26, 2013 10:57 am    Post subject: Reply with quote
Ok, here is it
PostPosted: Tue Mar 26, 2013 11:01 am    Post subject: Reply with quote
you forgot to include the rpt file.
jakub.jnm
PostPosted: Tue Mar 26, 2013 11:27 am    Post subject: Reply with quote
I can't find the file.
In options -> output i have set Error file. But in folder were is program saved is no file with this suffix.
PostPosted: Tue Mar 26, 2013 11:43 am    Post subject: Reply with quote
you need to enable report files : options, compiler, output
jakub.jnm
PostPosted: Tue Mar 26, 2013 11:57 am    Post subject: Reply with quote
Ok, i did it.
PostPosted: Tue Mar 26, 2013 1:12 pm    Post subject: Reply with quote
still no rpt. i have no more time, sorry.
jakub.jnm
PostPosted: Tue Mar 26, 2013 1:47 pm    Post subject: Reply with quote
Sad but there is no file with this suffix!
I have selected in output all options, but after compile there is no file with this suffix.
So i tried compile another file with wrongs and there was rpt file.
If i compile this code the rpt file wasn't create.
I don't know what to do.[/img]
jakub.jnm
PostPosted: Tue Mar 26, 2013 3:00 pm    Post subject: Reply with quote
Please!! Have you any suggets?
PostPosted: Tue Mar 26, 2013 3:07 pm    Post subject: Reply with quote
how about the version you use?
bzijlstra
Bascom Ambassador
PostPosted: Tue Mar 26, 2013 8:38 pm    Post subject: Atmega32 - Atmega8? Reply with quote
In the text you are talking about a atmega32. In the code you put in this forum and in the rar-files an atmega8 is used.
Could that be the problem?
When you got your hardware finished and programmed, the first test could be a PING to the IP-address.
Have fun
Ben Zijlstra
jakub.jnm
PostPosted: Thu Mar 28, 2013 8:45 am    Post subject: Re: Atmega32 - Atmega8? Reply with quote
Have fun
Ben Zijlstra
Ok i have new code from examples of Bascom.
Here is it:
'name                     : tcpip.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demo: CONFIG TCPIP
'micro                    : Mega162
'commercial addon needed  : only hardware
$regfile = "m32def.dat"
$crystal = 16000000
Const Sock_stream = $01                                     ' Tcp
Const Sock_dgram = $02                                      ' Udp
Const Sock_ipl_raw = $03                                    ' Ip Layer Raw Sock
Const Sock_macl_raw = $04                                   ' Mac Layer Raw Sock
Const Sel_control = 0                                       ' Confirm Socket Status
Const Sel_send = 1                                          ' Confirm Tx Free Buffer Size
Const Sel_recv = 2                                          ' Confirm Rx Data Size
'socket status
Const Sock_closed = $00                                     ' Status Of Connection Closed
Const Sock_arp = $01                                        ' Status Of Arp
Const Sock_listen = $02                                     ' Status Of Waiting For Tcp Connection Setup
Const Sock_synsent = $03                                    ' Status Of Setting Up Tcp Connection
Const Sock_synsent_ack = $04                                ' Status Of Setting Up Tcp Connection
Const Sock_synrecv = $05                                    ' Status Of Setting Up Tcp Connection
Const Sock_established = $06                                ' Status Of Tcp Connection Established
Const Sock_close_wait = $07                                 ' Status Of Closing Tcp Connection
Const Sock_last_ack = $08                                   ' Status Of Closing Tcp Connection
Const Sock_fin_wait1 = $09                                  ' Status Of Closing Tcp Connection
Const Sock_fin_wait2 = $0a                                  ' Status Of Closing Tcp Connection
Const Sock_closing = $0b                                    ' Status Of Closing Tcp Connection
Const Sock_time_wait = $0c                                  ' Status Of Closing Tcp Connection
Const Sock_reset = $0d                                      ' Status Of Closing Tcp Connection
Const Sock_init = $0e                                       ' Status Of Socket Initialization
Const Sock_udp = $0f                                        ' Status Of Udp
Const Sock_raw = $10                                        ' Status of IP RAW
Const Epr = 1
Print "Init , set IP to 192.168.0.8"                        ' display a message
Enable Interrupts                                           ' before we use config tcpip , we need to enable the interrupts
Config Tcpip = Int0 , Mac = 12.128.12.34.56.78 , Ip = 192.168.0.8 , Submask = 255.255.255.0 , Gateway = 0.0.0.0 , Localport = 1000 , Tx = $55 , Rx = $55
Print "Init Done"
'Use the line below if you have a gate way
'Config Tcpip = Int0 , Mac = 12.128.12.34.56.78 , Ip = 192.168.0.8 , Submask = 255.255.255.0 , Gateway = 192.168.0.1 , Localport = 1000 , Tx = $55 , Rx = $55
'The next code is optional. It shows how to change the IP at run time
#if Epr = 1
    Dim Xx As Eram Long                                     ' this is 4 bytes of EEPROM
    Dim Zz As Long                                          ' this is a long
    Zz = Xx                                                 ' read eeprom
    Dim B4 As Byte
    B4 = 8
    'use maketcp to create an IP number
    'notice that last param is a variable.
    'all bytes could be variables of course
    Zz = Maketcp(192 , 168 , 0 , B4)
    'in reverse order
    Zz = Maketcp(b4 , 9 , 168 , 192 , 1)
    'simplest form
    Zz = Maketcp(192.168.0.6)
    Print Ip2str(zz)
    Settcp 12.128.12.34.56.78 , Zz , 255.255.255.0 , 0.0.0.0
    '                            ^   notice the variable that holds the IP address 192.168.0.8
    '                                from the EEPROM data line below
#endif
  nop
  ' a ping should now work
$eeprom
' take care, data is stored byte, by byte so reversed notation is used
Data 8 , 0 , 168 , 192                                      '   this is 192 , 168 , 0 , 8
$data
But if i load it into chip, terminal didn't write "Init Done".
ooh :/
I have connected SC,MOSI,MISO before datasheet of Wiznet W5100 and ATMEGA32.
Any suggests? Sad
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
Page 1 of 3
