program via usb?
cordless
PostPosted: Sat Oct 29, 2005 12:38 am    Post subject: program via usb? Reply with quote
I am currently programming via the "sample electronics programmer" via LPT1. My new laptop only has a couple of USB ports... what are my options?
Thanks in advance.
nasser_attarzadeh
PostPosted: Sat Oct 29, 2005 4:54 am    Post subject: Reply with quote
you can use stk500 programmer that use usb port
or use avr isp programmer and then use usb to rs232 for it
View user's profile Yahoo Messenger
Luciano
PostPosted: Sat Oct 29, 2005 9:41 am    Post subject: Reply with quote
Try that:
http://www.usbgear.com/USBG-220D2.html
I am not sure is going to work.
Timing could be critical with your LPT programmer.
Development on a PC without a serial port it's almost
impossible. You will need a serial port while debugging or
when your program inside the AVR uses the serial port to
communicate with a PC.
The Atmel STK500 uses the serial port. (Not USB).
Best regards,
Luciano
bryon
PostPosted: Sun Oct 30, 2005 3:35 am    Post subject: Reply with quote
Hi Cordless,
From AVR Freaks:
http://www.avrfreaks.net/index.php?module=FreaksTools&func=viewItem&item_type=tool&item_id=522
bryon
ATIU
PostPosted: Sun Oct 30, 2005 1:12 pm    Post subject: Reply with quote
How about this
http://www.fischl.de/usbasp/
cordless
PostPosted: Mon Oct 31, 2005 2:57 am    Post subject: Reply with quote
Would a pcmcia legacy parallel card work? It adds a couple of parallel ports which can be set for lpt1,2 or 3. What ya'll think?
Luciano
PostPosted: Mon Oct 31, 2005 1:20 pm    Post subject: Reply with quote
Yes.
Single RS232 Serial Comms & Centronics Parallel Port PCMCIA Card - ELAN SP230
http://www.elandigitalsystems.com/interface/sp230.php
Expensive! ($$$)
Luciano
Jason
PostPosted: Wed Nov 02, 2005 12:32 pm    Post subject: Reply with quote
Does anyone know when Mark's USB programmer will be ready?
Cheers,
Jason.
PostPosted: Fri Nov 04, 2005 7:33 pm    Post subject: Reply with quote
Hello,
You can visit the big site : www.avrfreaks.net it is a little bit confuse but ...
another one www.kanda.com typicaly english Wink
bon courage
JP
