attiny1634 and serial communication (BUG in attiny1634 ?)
muellner
PostPosted: Thu Jan 17, 2013 12:08 pm    Post subject: attiny1634 and serial communication (BUG in attiny1634 ?) Reply with quote
i encounter a problem when trying to
config com1=9600, synchrone=0,parity = none,stopbits=1,databits=8,clockpol=0
I get a compile error :
.EQU not found, probably using functions that are not supported by the selected chip [UCSRC]
There are also errors if i try to :
config serial = buffered, size=20
saying interrupt USRX not found.
When i search attiny1634.dat i cannot find USRX, also no USRC ...
Any suggestions ?
muellner
PostPosted: Thu Jan 17, 2013 1:30 pm    Post subject: Reply with quote
According to the datasheets, tiny1634 and mega162 are using the same USART structure.
If I compile my prog with regfile m162def.dat, i dont get any error. So to me, it seems there's an error in the
attiny1634.dat,
but i don't know how to fix it ....
thx in advance
Wilhelm
Meister
PostPosted: Thu Jan 17, 2013 1:33 pm    Post subject: Reply with quote
Good to know. I am right now preparing a PCB for using Attiny1634. So I should postpone it until a fix has been found...
In the dat files there is a difference:
Attiny1634:
uarts=2 ;2 uart in this chip
uart1=5 ; extended uart
uart2=5
m162:
uarts=2 ; 2 uart in this chip
uart1=3 ; extended uart with shared register ubr/ucsrc ursel bit must be o to update UBRRHI
uart2=3 ; dito
Don't know what to do with it.
Meister
PostPosted: Thu Jan 17, 2013 2:28 pm    Post subject: Reply with quote
search for :
UCSR0C = $24
and add this below :
UCSRC = $24
or simply change the ucsr0c into ucsrc
PostPosted: Thu Jan 17, 2013 8:45 pm    Post subject: Reply with quote
also the INT section must look like this :
[INTLIST]
count=27
INTname1=INT0,$002,GIMSK.INT0,GIFR.INTF0
INTname2=PCINT0,$004,GIMSK.PCIE0,GIFR.PCIF0
INTname3=PCINT1,$006,GIMSK.PCIE1,GIFR.PCIF1
INTname4=PCINT2,$008,GIMSK.PCIE2,GIFR.PCIF2
INTname5=WDT,$00a,WDTCSR.WDIE,WDTCSR.WDIF
INTname6=ICP1@CAPTURE1,$00c,TIMSK.ICIE1,TIFR.ICF1
INTname7=OC1A@COMPARE1A,$00e,TIMSK.OCIE1A,TIFR.OCF1A
INTname8=OC1B@COMPARE1B,$010,TIMSK.OCIE1B,TIFR.OCF1B
INTname9=OVF1@TIMER1,$012,TIMSK.TOIE1,TIFR.TOV1
INTname10=OC0A@COMPARE0A,$014,TIMSK.OCIE0A,TIFR.OCF0A
INTname11=OC0B@COMPARE0B,$016,TIMSK.OCIE0B,TIFR.OCF0B
INTname12=OVF0@TIMER0,$018,TIMSK.TOIE0,TIFRK.TOIE0
INTname13=ACI,$01a,ACSRA.ACIE,ACSRA.ACI
INTname14=ADCC@ADC,$01c,ADCSRA.ADIE,ADCSRA.ADIF
INTname15=URXS,$01e,UCSR0D.RXSIE0,UCSR0D.RXS0
INTname16=URXC@SERIAL,$020,UCSR0B.RXCIE0,UCSR0A.RXC0
INTname17=UDRE,$022,UCSR0B.UDRIE0,UCSR0A.UDRE0
INTname18=UTXC,$024,UCSR0B.TXCIE0,UCSR0A.TXC0
INTname19=URSX1_RXS,$026,UCSR1D.RXSIE1,UCSR1D.RXS1
INTname20=URXC1,$028,UCSR1B.RXCIE1,UCSR1A.RXC1
INTname21=URDRE1,$02a,UCSR1B.UDRIE1,UCSR1A.UDRE1
INTname22=UTXC1,$02c,UCSR1B.TXCIE1,UCSR1A.TXC1
INTname23=USI_START,$02e,USICR.USISIE,USISR.USISIF
INTname24=USI_OVF,$030,USICR.USIOIE,USISR.USIOIF
INTname25=TWI,$032,TWSCRA.TWDIE,TWSSRA.TWDIF
INTname26=ERDY,$034,EECR.EERIE
INTname27=QTRIP,$036,
muellner
PostPosted: Fri Jan 18, 2013 12:00 pm    Post subject: Thanx ! Reply with quote
Problems solved, BIG thanks to Mark !
Wilhelm
thiagorod
PostPosted: Fri Nov 21, 2014 6:35 pm    Post subject: Reply with quote
Hello,
Sorry for the late reply on that subject, but I have a project with Attiny1634 and I canīt find the attiny1634.dat file under BASCOM folder. I am using DEMO 2.0.7.5 version. Is this file only available in full BASCOM version?
Best Regards,
